Stator problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 05-17-2014, 01:53 PM Thread Starter
Crowley
crowley1027's Avatar
Stator problem
Riding today, I had nightmarish things happen to me. Running out of gas, I got gas just in time. 2 miles after, it choked and died, and I was able to pop start it in first since I was rolling. In the next ten miles, I dealt with bouts of clean running mixed with bad engine coughs and sputters, with a hell of a wacky tachometer.
Got home, and battery is at 12.5v, but doesn't go over 13 when revved up to 5k. I'm getting 30 amp readings from the stator-r/r connector (unplugged from the r/r) across each combination at idle. I'll go out now to check resistance.
Edit - on 200 ohm setting, touching the voltmeter leads together gives me 21 ohms. Each combination of stator wires (testing at the connector previously mentioned) starts at 150 ohms and drops down to high 90s. I switched it over to that strange arrow with a line setting (continuity maybe) and got around 150.
It's a tpe stator, I wonder what is happening......
Also note, after opening the oil cap, i get light, wispy white smoke.
crowley1027 is offline
post #2 of 21 (permalink) Old 05-17-2014, 02:19 PM Thread Starter
Crowley
Anyone can feel free to call me. I hope I don't regret posting my number... 401 675 7442
post #3 of 21 (permalink) Old 05-17-2014, 03:17 PM
What is the actual AC voltage on each leg? Does any of the legs ground ground out (engine off, etc) - check resistance to the frame/ground.
post #4 of 21 (permalink) Old 05-17-2014, 06:43 PM Thread Starter
Crowley
Great news - I guess the r/r plug shook loose a bit during the hundreds of miles. I did some tests, plugged it back in and voila, I got almost 14v at 3k rpm. 60amps at 3k too.
:thumbsup:
post #5 of 21 (permalink) Old 05-17-2014, 08:06 PM
Chasin' the blacktop
Spencer1's Avatar
60 amps, wow! that's one hell of a stator.... but I suspect your stator is putting out less than 35 amps. Factory stators are rated for 27 amps and TPEs do a little better.
Glad it was just your plug and not a bad wind on the stator.
North Georgia
Spencer1 is offline
post #6 of 21 (permalink) Old 05-20-2014, 09:25 AM Thread Starter
Crowley
Could this issue be from a bad ignition switch? Bad r/r?
Updated info: when the bike goes wonky, the tachometer drops instantly to 0. Sometimes with the "hiccups", it goes 300rpm higher like I blipped the the throttle super fast.
Riding the other day it died out fast, not much sputtering (although for 5 minutes before this, it coughed down the road).... I tried to restart with no luck - it wouldn't even turn over.
Wiggle of the key, and it started right up and didn't complain for the next 45 miles.
I'm hesitant to believe the sporadic cutouts and lack of battery charging can be the ignition switch... Well I know that the ignition switch won't affect charging.... I don't know......
Sigh.
post #7 of 21 (permalink) Old 05-20-2014, 01:26 PM
Sounds like a keyswitch issue ,there are a couple of write ups on taking it apart cleaning and repairing on here. Maybe a sticky .If not there should be one,it is a known issue. Good luck, you have more than likely found your problem Nate.
post #8 of 21 (permalink) Old 05-20-2014, 02:43 PM
Sounds like a key switch issue ,there are a couple of write ups on taking it apart cleaning and repairing on here. Maybe a sticky .If not there should be one,it is a known issue. Good luck, you have more than likely found your problem Nate.
x2 - same here
post #9 of 21 (permalink) Old 05-20-2014, 04:42 PM
GloryRider's Avatar
Might also want to check your fuses...
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #10 of 21 (permalink) Old 05-22-2014, 03:54 PM Thread Starter
Crowley
Don't want to jinx myself, but I cut the r/r connector and the respective 6pin from the harness, spade connected them all, shrink wrapped them and taped them....
Haven't seen a problem yet.
