How much light? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 09-14-2007, 09:07 PM Thread Starter
How much light?
I have added driving lights and light bar, but I am concerned about the "questionable" electrical system on the Vulcan. Any comments about wattage that I should watch out for? I will be using 25watt halogen bulbs (not sealed beams). Appreciate any suggestions and comments.
rfg98 is offline
post #2 of 5 (permalink) Old 09-14-2007, 10:11 PM
I ran two 55 watt driving lite made for a car for a few months along with 80 watt high beam. I never had any problem, however, most of my driving is on the open road at higher speed. And also I ussually used them only at nite when needed. Now I have 35 watt sealed beams, and try to remember to turn them off when I stop and put my low beam on. This way I have the least electicity used when starting up.
post #3 of 5 (permalink) Old 09-14-2007, 11:09 PM
At 25 watts each, ya should be OK.
But like stated above, if you use then when you NEED them, not just to have them lit up, it's even better.
post #4 of 5 (permalink) Old 09-15-2007, 09:47 AM
93VN750's Avatar
Don't parade ride or idle a lot and you should be fine. Over 2500 rpm's, you have all the power you need.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 5 (permalink) Old 09-15-2007, 02:09 PM Thread Starter
How much light?
Thanks all for the info,I will watch the rpms and when I use them
rfg98 is offline
