vulcan 750 won't fire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-04-2014, 10:34 PM Thread Starter
Cool vulcan 750 won't fire
Would a bad stator cause my bike (1994 vulcan 750) not fire? The spark is orangish color at the plug. It rolls over but just won't fire. I do know the stator needs replaced, just not sure if that would prevent it from firing
tinman is offline
post #2 of 4 (permalink) Old 05-04-2014, 11:29 PM
It will start and run on a bad stator, but a weak battery is deal killer.
Mine had both a bad stator and weak battery, it would crank some, then backfire. A new AGM type battery and she fired up every time.
Orange spark is never good, but you can't troubleshoot it if the battery is down.
post #3 of 4 (permalink) Old 05-05-2014, 07:03 AM Thread Starter
The battery is brand new. Could the coil be bad? Any suggestions?
tinman is offline
post #4 of 4 (permalink) Old 05-05-2014, 09:07 AM
Do you know what the battery voltage is?
The coil can be tested, and also check voltage at the coil. Is all the spark orange or just on one cylinder?
Have you tested the stator and r/r?
Could be a problem with wiring or the junction box.
There's a free download here for the repair manual which has the test procedures.
