Need help with ignition switch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By WilliamTech
  • 1 Post By Goofyfoot2001
  • 1 Post By Spockster
post #1 of 4 (permalink) Old 05-04-2014, 06:39 PM Thread Starter
Mattman's Avatar
Hi guys,
I have been following the procedure described in the Verses for cleaning the ignition switch and my bike ('94) seems to be slightly different than what was described there. For example, the Verses indicate that the switch will have two wires that need to be disconnected to remove the assembly from the bike, one multiconnector and one single wire, but mine has the multiconnector and two wires. I disconnected all three, but am wondering why the difference.
Anyway, I now have the switch out of the bike and have some questions abut what I see, the descriptions I have read don't seem to quite match what I have but maybe it's all just a matter of perception.
-The four tabs: I have attached some photos to help me identify what needs to be unclipped in order to open it up, I have read so many warning about how fragile this is that I don't want to go all animal on it without knowing for sure what I am doing
-I have seen references made to the "puck", which I am assuming is the lower piece with the wires attached to it. Because it is not quite circular, I wanted to make sure that this is indeed the puck
I am going to get into this some evening this week, if you have any clarification or words of advice to offer before I proceed I would be very grateful.
Thanks,
Matt
ID:	15345   Click image for larger version
ID:	15353   Click image for larger version
Matt
Passaic County, NJ
1994 VN 750
April 2011- 30K miles
TOC MCCT 4/2012
New-to-me extended backrest 5/2012
Tourmaster bags 5/2012
Replaced driveshaft coupler and final drive-- ignored the spline lube recommendation too long and got burned 8/2012
Back on the Road 9/2012
De-POOGSed 6/2013
NGK Iridium Plugs 7/2013
New AGM battery 4/2014
Mattman is offline
post #2 of 4 (permalink) Old 05-04-2014, 07:32 PM
Originally Posted by Mattman View Post
Hi guys,
Thanks,
Matt
You found the Puck..... open the puck VERY carefully..... suggest a kitchen table covered with a cloth (or similiar set-up with good light)....little springs will jump out .......LOL
Clean contacts shinny.......
take your time..... you should not have any problem which one cannot solve.
Go for it !
Ron Ryman likes this.
post #3 of 4 (permalink) Old 05-04-2014, 07:56 PM
Even if you break the tabs, slme superglue and a zip tie will be fine. I never took mine off the bike, just opened it still attached. The puck does need to be pressed against the wire side in the end. It can't be loose.
post #4 of 4 (permalink) Old 05-04-2014, 08:02 PM
I haven't done a switch, but pics 1 and 2 are lock tabs. Sometimes it's safer to pry the cover/case out instead of pushing the tab in.
