Rust - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-03-2014, 10:19 PM Thread Starter
Mike DeAngelo's Avatar
Rust
My HID lighting went on the blink the other day so I had to switch to the high beam. I took apart the front headlight only to find rust so I sprayed flat black rust converter after sanding down the rough stuff. I took the lighting connections apart and found corrosion and moisture. I used a dremel to clean things up and used liquid electrical tape to seal a new HID unit I had on hand. I was surprised the water had snuck up some of the wires even though all cable connections were taped with electrical tape. I now know I didn't do such a great job. I feel much better now and am one step closer to painting the chrome flat black to avoid the hardship of the rust demon. Oh yea, I removed the fairing and had to drill out three bolts. I had an easy out from Harbor Freight. Made like Sheet but it did the job in all cases.
It was neat to see the goop in the plugs which had a fair amount of tape on them. I need to be much more careful in the future. This liquid electrical tape is the bomb!
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
post #2 of 3 (permalink) Old 05-04-2014, 01:09 AM
If ya ever make it up here (snakes are out btw)....I can soda blast it for ya.......but hay...ya can always go aftermarket custom with a 8"....
My buddy Ed has em at his shop....7 miles....
post #3 of 3 (permalink) Old 05-04-2014, 09:26 PM Thread Starter
Thanks Man, I need to come up and see you. I got behind on my taxes and now I'm working for the man. Trying to get caught up. I'll make it up this summer. You can count on it.
I loved the soda/sand blaster at college. I striped my fenders and gas tank using it. Then baked and powder coated them. Was one of the best experiences I've ever had.
Chilhowee Tank Bra
Barons Big Air Kit
