Battery terminal melted - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-28-2007, 12:40 PM Thread Starter
I just got my bike running. I have just put a new battery in it. I did not get the MF one but the one I got came from the Kawasaki dealer. This morning I went to run the gas out of it because I still have a hose or 2 to replace. When I went to start it would not even turn over. I took off the seat and the positive side post was melted. Any Ideas on this would be great seems as though I am new to working on bikes. Thanks
86vulcanNB is offline
post #2 of 10 (permalink) Old 08-28-2007, 02:11 PM
85 VN 700
curtis97322's Avatar
I'm almost wondering if you're seeing acid damage - just not sure how it'd get up there.
At the same time - I'm pretty sure that if it was electrical your bike would have went up in flames if it was hot enough to melt a post.
Anyone got any ideas other than acid?
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #3 of 10 (permalink) Old 08-28-2007, 02:54 PM
Crobins365's Avatar
Acid doesn't usually melt the lead, though, just leaves that nasty white fuzz. What would happen (theoretically) if the bike were hooked up backwards (neg and pos terminals reversed)?
C
Crobins365 is offline
post #4 of 10 (permalink) Old 08-28-2007, 03:27 PM
Spriddle's Avatar
The only thing that comes to mind is that where the positive cable connects to the battery,if it were a loose connection and/or dirty it would generate heat.
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
post #5 of 10 (permalink) Old 08-28-2007, 04:13 PM
That's what I would think too.
Is it the lead terminal on the battery, or the wire connection that attaches to the battery that melted?
If ya can post a pic, it'd be a big help in trying to figure out what happened.
post #6 of 10 (permalink) Old 08-28-2007, 04:54 PM Thread Starter
It was the lead terminal on the battery. I will post a pic in a minute
post #7 of 10 (permalink) Old 08-28-2007, 08:43 PM
HAWK
Ccspinner's Avatar
Heat generated that much could be caused by a short.
Look at the postitve cable and see if it got worn through or pinched somewhere.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 10 (permalink) Old 08-28-2007, 09:51 PM
james brill's Avatar
if pure lead was used for terminal it might lower the melting point.I've bought a battery that had terminals so soft I was able to twist them off the battery by finger pressure. just a thought.
james brill is offline
post #9 of 10 (permalink) Old 08-29-2007, 03:49 PM
"I took off the seat and the positive side post was melted."
Side post?
What is describe here would almost dictate catastrophic arc damage to battery case, frame, fused, burned off insulation from heavy wire or ruptured battery case....
Is there any other evidence other than the battery terminal? Picture posted yet?
flash.sr is offline
post #10 of 10 (permalink) Old 08-29-2007, 11:26 PM Thread Starter
no top post mounted no other damage than the top positive battery terminal
