Stator wires.. HELP! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-18-2014, 06:05 PM Thread Starter
I took the wiring harness out today to fix some broken wires, rewrap in some new wire loom and generally clean things up. Most things are obvious, either by placement, wire colors, harness, etc... But of course there were a few wires that were no obvious - for those I marked them with a marker.
I go to reconnect the wires coming out of the stator... the clip, easy, then I come to three wires.. I marked these, and in my infinite wisdom when cleaning them I cleaned the marks right off.
I've got three black wires coming out of the stator. They all look the same, same color/thickness, no color stripes that I can see. I've got three yellow wires that go into the wiring harness - again, same color, no stripes, etc...
At first though, I can plug any of them into any and it should work. Same colors, right? The logical side of me thinks these are +/-/GRND, so I really don't want to mess them up.
Any suggestions / ideas?
kagaku is offline
post #2 of 11 (permalink) Old 04-18-2014, 07:02 PM
emtdon's Avatar
it doesn't matter which way three stator wires hook back up. that's the reason the aren't different colors.
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #3 of 11 (permalink) Old 04-18-2014, 07:40 PM
Cool.this saved me a thread.lol
post #4 of 11 (permalink) Old 04-18-2014, 08:10 PM Thread Starter
Thanks!
'92 Kawasaki Vulcan 750
Mods:
Rattle-can high gloss black paint job
Frame, engine, Headers/exhaust painted satin black
Ears shaved, K&N pod filters
TPE Stator, MOSFET R/R, Magna Power AGM battery
Pickup Coil mod
New mirrors, grips, cables
VN900 seat
Straight pipes with 8" baffles
kagaku is offline
post #5 of 11 (permalink) Old 04-18-2014, 09:56 PM
emtdon's Avatar
no problem glad i could help ya.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #6 of 11 (permalink) Old 04-18-2014, 10:06 PM
Okiebezer's Avatar
Check those connections closely. They have a tendency to corrode and heat up. Many suggest using the dialectric grease on contacts. Some of us have braided these connections, soldered and shrink wrapped.
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #7 of 11 (permalink) Old 04-18-2014, 10:26 PM
I also have a super hi res jpg of the wiring diagram if one need it....just pm me yer email....BIG file....no it wont go into yer Iphones....actually, it kills em on contact, lol....kidding....my file is eant to be downloaded to desktop, then printed on a good printer....800dpi if I remember right....
post #8 of 11 (permalink) Old 04-18-2014, 10:51 PM
Okiebezer's Avatar
Might want to move the rectifier...
https://www.vn750.com/forum/showthread.php?t=17275
post #9 of 11 (permalink) Old 04-19-2014, 12:33 AM Thread Starter
I plan to do this when I move the rectifier. Never heard of dielectric grease, though. Guess it won't matter once I solder it all together.
Mods:
Pickup Coil mod
VN900 seat
kagaku is offline
post #10 of 11 (permalink) Old 04-19-2014, 04:55 PM
I sent you the diagram btw.....
