Make your own LED lights. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-23-2007, 10:12 AM Thread Starter
I've been looking around for some answers on led wiring ("How to get it right") & this is what I found. I found it extremely usefull, especially the calculator!
http://www.lsdiodes.com/tutorial
Direct page link. http://www.lsdiodes.com/shop/index.p...cb79ee94209c42
post #2 of 5 (permalink) Old 08-23-2007, 02:16 PM
I had saved a site that you were able to punch in the specifics of the circuit ya wanted to make and it'd tell ya how to go about making it.
I'm pretty sure I got it from Hizzo, so it might be in a post here somewhere.
It's been awhile, but I'll see if I can find it and post back.
EDIT: Here it is.... http://led.linear1.org/led.wiz
And a search tip for this site....
To search posts about LED lights, 3 letters is too small a word, use LEDs and you'll get better results.
post #3 of 5 (permalink) Old 08-24-2007, 01:24 AM
I like that calculator better. It gives different configuration options and gives power disipation and current draw.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #4 of 5 (permalink) Old 08-24-2007, 03:05 AM
Yep, tells ya just what ya need to make it just how ya want.
post #5 of 5 (permalink) Old 09-07-2007, 10:13 AM Thread Starter
More direct info for use.
For 3.3 volts LEDs (blue, white etc.)
1 LED - 470 ohms (1/2 watt)
2 LEDs - 270 ohms
3 LEDs - 120 ohms
4 or more LEDs - Use multiple arrays of LEDs
For 2.0 volts LEDs (red, amber etc.)
1 LED - 560 ohms (1/2 watt)
2 LEDs - 470 ohms (1/2 watt)
3 LEDs - 330 ohms
4 LEDs - 220 ohms
5 LEDs - 100 ohms
6 or more LEDs - Use multiple arrays of LEDs
12V(positive terminal) ------LED------LED------LED------Resistor------(negative terminal)
