10amp relays and LEDs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-19-2007, 08:36 PM Thread Starter
Question 10amp relays and LEDs
A while back the local Advance Auto had some of those little led accent lights on clearance so I picked up a pair for like $2. Finally got around to installing them today. I was going to use an existing circuit form my old driving lights since it was already switched and had a 10a relay. Could not get the lights to work using the relay. Tested everything with my volt meter and it everything was connected as it should be. I had juice at the appropriate blade connector, but the lights just wouldn't come on. Finally just took the relay out and wired the lights into the switch circuit and all is well. But why wouldn't it work on the relay? Does using a relay require a certain amount of draw to work (less than the LEDs pull)? Surely these little LEds are not pulling more than 10a?
UncleGomer is offline
post #2 of 7 (permalink) Old 08-19-2007, 09:14 PM
You may already know, but led's have to be connected only one way. Electicity will not run both ways through them.
post #3 of 7 (permalink) Old 08-19-2007, 09:25 PM Thread Starter
Roger that. When I was trying to use the relay, I made sure to rule out bad leds or wrong wires by putting them on good, unswitched power and they worked fine
post #4 of 7 (permalink) Old 08-19-2007, 09:48 PM
HAWK
Ccspinner's Avatar
Most relays need 30mA to switch them. The draw that they are hooked up tp does not matter.
Yes LED's cant be hooked up in revierse, they wont work.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 7 (permalink) Old 08-19-2007, 10:11 PM
I use relays used on cars that run the fuel pump or radiator fan. They work great.
post #6 of 7 (permalink) Old 08-19-2007, 10:43 PM
GREMLINS!!!
Those LED's may actually be gremlin orbs.
Shake a bell at them before ya do any riding!! LOL
post #7 of 7 (permalink) Old 08-19-2007, 11:34 PM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
Bring the setup to Ky Lake. We will figure it out or put it in the Pick-Pitcher!!!
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 55,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
