Yuasa Battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-17-2007, 01:39 AM Thread Starter
Yuasa Battery
How often do you need to charge these batteries?
I've had it almost 3 weeks, no hotstart problems but, for the last couple days it was running really weak and then suddenly would not turn the starter over anymore. I hooked up the charger this eve when I got home from work. It was showing green light (fully charged). I left it charging for a few minutes anyway while I put the seat and all back on. (I ran a tether down by the fender so I can hook the charger up anytime wothout having to remove the seat anymore) After a few minutes of charging I tried the starter and it fired right up! Not only that but the charger light changed to yellow (charging) and has been charging for a couple hours now.
I didnt see anything in the battery manual about periodic recharging. Do these batteries need to be constantly recharged, or do I need to begin looking into my recharging and electrical systems?
vn750joe is offline
post #2 of 9 (permalink) Old 08-17-2007, 01:45 AM Thread Starter
Oh BTW I've had the battery for about 3 weeks, not the bike.
And I ride nearly every day, about 100+ miles per week. So I was thinking that should be plenty to keep it charged?
vn750joe is offline
post #3 of 9 (permalink) Old 08-17-2007, 01:50 AM
bj31702's Avatar
Send a message via Yahoo to bj31702
Have the battery load tested. Even new ones can be bad.
Check the charging system at the battery terminals.
'09 Nomad e sold
'85 VN700 A1 (needs work)
'11 Voyager
bj31702 is offline
post #4 of 9 (permalink) Old 08-17-2007, 01:56 AM Thread Starter
Ok, so I'll take that to mean that as long as I'm riding, the bike should not need recharging every few weeks.
vn750joe is offline
post #5 of 9 (permalink) Old 08-17-2007, 02:48 AM
bj31702's Avatar
Ya Should only need recharged if its sat for awhile. I read that a batter will loose 1% of its charge everyday it sits.
'09 Nomad e sold
'11 Voyager
bj31702 is offline
post #6 of 9 (permalink) Old 08-17-2007, 04:34 AM
Make sure the battery connections are tight/clean, as well as frame ground and stator connections.
It sounds like something may be loose or dirty.
post #7 of 9 (permalink) Old 08-17-2007, 06:31 AM
I agree with hyper. Check them connections
piromedicx is offline
post #8 of 9 (permalink) Old 08-17-2007, 01:35 PM
Benjammin'
BSkaggs513's Avatar
I second the agreement with Hyper. Especially the ground connectoins all the way through to the motor. Good luck!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #9 of 9 (permalink) Old 08-17-2007, 10:01 PM Thread Starter
Thanks guys.
vn750joe is offline
