Stop electrical connector corrosion - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 12-15-2004, 11:12 AM Thread Starter
Sgt Mike's Avatar
Lightbulb Stop electrical connector corrosion
To prevent and stop electrical connector corrosion this product
comes highly recommended. It's called PENETROX A
The electrical and electronic techs here at the Mack Trucks Power
Train manufacturing facility say that it makes the connector highly
water resistant and if moisture gets in the connector, corrosion
will not set in. I'm told that a little goes a very long way. This
product can be had at electrical supply places. I didn't check with
Home Depot or Lowes yet to see if they stock it.
Sgt Mike is offline
post #2 of 8 (permalink) Old 06-15-2006, 08:26 AM
Rubline's Avatar
Dielectric grease will do the same thing. Unplug and clean your connections then put a small amount of grease on them and then plug them back together.
Rubline is offline
post #3 of 8 (permalink) Old 06-22-2006, 09:48 PM
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
With a sealed Battery there should be no problem with corrosion normaly.
norsseman is offline
post #4 of 8 (permalink) Old 06-23-2006, 09:50 PM
Gnarly Jokester
norsseman's Avatar
Where can I by "PENETROX A" or "Dielectric" ? Sounds like a wonder
lubricant or sorts.
post #5 of 8 (permalink) Old 06-24-2006, 02:00 AM
2FAS4U
Dielectric grease is available at any parts store, such as Autozone. It is used on battery terminals and ignition parts. Should be a dollar or two.
2fas4u is offline
post #6 of 8 (permalink) Old 06-25-2006, 05:25 PM
Once Banned
cegodsey's Avatar
I checked Home Depot, they have some other brand. Is dielectric grease a spray? I didn't get their brand, 'cause I thought grease means it's in a tube. They didn't have anything other than spray.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #7 of 8 (permalink) Old 06-26-2006, 12:12 AM
Loran in Npvl IL's Avatar
I have only seen it in a tube but if it is dielectric grease and a spray that could also work - I use to use lithum spray grease (until I got some water proof bearing grease).
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #8 of 8 (permalink) Old 06-27-2006, 02:46 PM
fergy's Avatar
I bought a can of dielectric grease at autozone that is pressurized and has a trigger. It's grease, but comes out like greased lightning if you hold the trigger too long. A little touch of the trigger and you get grease for about 20 seconds. I'd rather have a tube you squeeze yourself... But hey it works.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
