starter ground wire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-01-2014, 11:56 PM Thread Starter
starter ground wire
where does the starters long black ground wire connect to? Anywhere on the frame or does it run somewhere specific?
I've looked through this forum as well as the manual. it does not give me a specific location.
thanks
djfeitl is offline
post #2 of 6 (permalink) Old 04-02-2014, 12:10 AM
Crowley
crowley1027's Avatar
Anywhere to the frame is fine as far as I know
I didn't make a good user name and I can't change it, so please call me Nate.
crowley1027 is offline
post #3 of 6 (permalink) Old 04-02-2014, 01:26 AM
That's not a ground, it's the hot wire from the solenoid.
post #4 of 6 (permalink) Old 04-02-2014, 07:17 AM
Yep the starter is grounded through contact with the engine. The only wire that comes off if it runs along the bottom of the engine and up to the right side cover where it is attached to the solenoid.
post #5 of 6 (permalink) Old 04-02-2014, 12:23 PM
Is true. I also purchased a solenoid off amazon and it works fine FYI. Prolly didn't need it but was trying to troubleshoot some warm starting issues.
http://www.amazon.com/Starter-Soleno.../dp/B0076AOXAU
post #6 of 6 (permalink) Old 04-02-2014, 02:16 PM
You will be very displeased with the results if you ground that wire & try to start your bike.
Ltms.
post #7 of 6 (permalink) Old 04-03-2014, 04:21 AM
You will be very displeased with the results ....
....lolol....fokkin Kanuck, lol.....
