Battery Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-10-2007, 01:13 PM Thread Starter
San Diego Vulcan Rider
DeForestSD's Avatar
Battery Question
Well, I was riding home from work and stopped at the mini-mart. Came out and could not start. The battery wound down to nothing. I was able to get it rolling and it started but sputtered and ran on one cylinder til I got her home. Popped the seat and found my negative battery terminal had loosened up. (The battery is about 1 year old Yuasa MF). Tightened it up, put the battery tender on and got a green light after about six hours. Rode to work today with no problem. My questions are:
1. Do you think running the battery down shortens the life or affects how long it will hold a charge?
2. What do you think about using a small dab of blue Loctite?
Thanks.
86' Vulcan, Stock & Lovin it!
Stator, R/R, splines lubed, ACCT's repl. at 25,200
Just turned 29,000 mi.
95' Vulcan, all stock, 9,700 mi.
John Spangler
DeForestSD is offline
post #2 of 4 (permalink) Old 08-10-2007, 01:53 PM
Calif Rider
weh44att's Avatar
I do not think a few times of running down the battery has any real affect on the battery. Plus the blue lock tight might affect a good contact with the negative lead.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 4 (permalink) Old 08-10-2007, 02:01 PM
Benjammin'
BSkaggs513's Avatar
You are not the first one who has had the battery terminals loosen up on their own. Instead of locktight, which may cause future problems with loosening or contact, you may want to get a small locking washer to put on the terminal bolt. If possible the kind with 'fins' instead of the offset would probably work best. And, it would probably help make contact better.
Just a thought.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #4 of 4 (permalink) Old 08-10-2007, 03:35 PM
Loran in Npvl IL's Avatar
I have had battery terminals loosen up on a bike. The main problem was I didn't tighten it up enough in the first place. I had gotten lazy and used screw driver and another time I had just used a plier. When I have used a socket I have not had problems
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
