Crowley
Blue wire bypass - headlight relay mod
This guide bypasses the headlight relay, lighting your headlight when you turn the key, instead of when the engine turns.
Don't ask me about the pros/cons of this; I'm sure it will be discussed.
Video detailing the procedure at https://www.youtube.com/watch?v=C1_1MTfiJb8
On the left side of the bike remove the side cover. Unscrew the bottom screw and pull the side cover off. If you are sitting on the side of the bike, facing the side cover, pull directly toward you.
http://i16.photobucket.com/albums/b5...323_061053.jpg
You will see a Palm sized black box with two connectors coming out the right side of the box. One is a smaller ten pin, one is an 8 pin.
http://i16.photobucket.com/albums/b5...323_061153.jpg
Don't make the mistake I made - don't touch the ten pin connector. I pulled the blue wire from the 10 pin and moved it to the 8 pin. This is WRONG.
Pull out the 8 pin connector.
http://i16.photobucket.com/albums/b5...323_061246.jpg
There is a blue wire. Pull the blue wire out of its spot (or push it from the front of the connector to reduce stress on the wires) and move it to the empty spot on the same connector.
http://i16.photobucket.com/albums/b5...323_061333.jpg
http://i16.photobucket.com/albums/b5...323_061559.jpg
If the spade connector pushes out as you push the connector in, just connect the plug, then push the spade connector into the empty spot to secure it.
Operation complete.
Operation complete.
Sponsored Links | |||
Sticky worthy?
Thanks, much appreciated! A reasonably easy mod to do, but having pictures to look at definitely works better for me to understand what is to be done.
1996 VN 750
2007 Vulcan Mean Streak SE
When I was younger I was afraid I'd die riding. Now that I'm old and falling apart, I'm afraid I won't.
Well done - a great detailed write up ...with pics !
Glad it's appreciated
Done
My headlight's bright light didn't work so I bought a new bulb. This didn't fix the problem.
I figured I had nothing to lose by switching this blue wire to bypass the headlight relay.
This fixed it. Bright light now works.
Thanks
Thanks
Glad it's still of use
Based on the diagram on page 15-36 in the manual, this bypasses the headlight fuse as well. May want to seriously consider adding an in-line fuse to protect things.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
Originally Posted by calebj
View Post
This is a great mod, and can't beat the price !
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
