Best Price for Bulbs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-01-2007, 03:19 AM Thread Starter
Question Best Price for Bulbs
Hey Guys and Gals,
Just wondering where the best place is to get a new bulb, and what should I expect to pay??
93 Vulcan 750
bulb type: H4 JA12V60/55W
Also without trying to sound too ignorant, that would be an obvious first replacement troubleshoot..........right??
Thanks in advance for your help!!!
kevin1222 is offline
post #2 of 7 (permalink) Old 08-01-2007, 12:46 PM
HAWK
Ccspinner's Avatar
Which bulb?
The tail lights and ft turn siganls are 1157, about $5 for 2
Rear turn signals are 1156, same price
HEadlights H4 I think and $15 to $30 depending on what headlight you get.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 7 (permalink) Old 08-04-2007, 08:14 AM
Benjammin'
BSkaggs513's Avatar
Can anyone tell me what the replacement bulb number is for the license plate light? I know some folks have used an LED panel on that, but I would like to look into just getting an LED bulb to stick in there, if it is available.
Also, has anyone had any luck with putting LED bulbs in the turn signals and replacing the flasher unit? Has anyone purchased the variable resistance flasher unit and how is that working on your bike?
Thanks.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #4 of 7 (permalink) Old 08-04-2007, 09:38 PM
A 9003 is the same as an H4. You can get them anywhere. I have seen them for less than 8 bucks at Wal-Mart
mnmkiller is offline
post #5 of 7 (permalink) Old 08-04-2007, 10:48 PM
HAWK
Ccspinner's Avatar
Plate bulb is a 97 I had to get one a while ago, a pack of 2 was under $5
Chad Falstad "Hawk"
Vroc #17649
post #6 of 7 (permalink) Old 08-05-2007, 03:36 PM
Benjammin'
BSkaggs513's Avatar
Chad,
Was that a incandescant bulb you replaced it with? I was wondering if an LED replacement bulb was available for the licence plate. I was kinda hoping for a 'plug-in' solution instead of a modification to use an LED back there.
Thanks.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
post #7 of 7 (permalink) Old 08-05-2007, 05:13 PM
HAWK
Ccspinner's Avatar
Yes just a plane bulb. I did not look for a led replacement at that time.
When it goes out I will look for a LED then.
Chad Falstad "Hawk"
Vroc #17649
