LED for turn signals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-26-2007, 10:24 PM Thread Starter
Dan
Does anyone know if LED bulbs are available for the turn signals? That question was asked on this board a while back but I can't find an answer.
Dan - Seattle
Dan is offline
post #2 of 5 (permalink) Old 07-26-2007, 10:49 PM
HAWK
Ccspinner's Avatar
You can get a bulb to replace the 1156 in the rear 1157 in the front, but you will still have to modify the blinker to make the blink rate normal.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 5 (permalink) Old 07-27-2007, 01:59 AM Thread Starter
Dan
>>>>>>you will still have to modify the blinker<<<<<<
Thanks,
I guess I'll forget it. I have the taillight/brakelight board and it works great!
Dan is offline
post #4 of 5 (permalink) Old 07-27-2007, 11:28 AM
Dan - Seattle
I tried them and I didnít like them at all. I went back to the regular bulbs for the blinker and LED for the rear light.
artybolt is offline
post #5 of 5 (permalink) Old 07-27-2007, 11:29 AM
Depends on which ones you buy. They have the standard LED bulbs that will require a module/load equalizer for the LED's, or you can spend more $ on the LED replacement bulbs that have a circiut board/resistor already installed in the base of the bulb that eliminates the module/load equalizer. You will usually find that the LED's with the built in resistor are not as bright as the ones that use a module/load equalizer.
racohoon is offline
