LED Indicators. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 02-28-2014, 03:07 PM Thread Starter
Big Nick's Avatar
Smile LED Indicators.
I bought them cheap,$10 the set,fitted them and flashed a bit to fast, started wiring in the voltage reduction units and found it a problem around the headlight area. Spock chimed in with some advice on a Flasher unit"$27" that reduced voltage and brought the flashing speed into line.
Thanks Spock all worked out well.
I now have some Flash, Flashers that blink at the right speed.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 8 (permalink) Old 02-28-2014, 03:31 PM
Send KC2DDG a PM about it....he's the guru of LEDs....he even makes his own sets....he can help ya....
post #3 of 8 (permalink) Old 02-28-2014, 04:46 PM
What LED's did you buy?
I sure hope you didn't wire in any resistors or "balancers" to fix the flash rates....that just adds current draw to the circuit and defeats the purpose of using LED's.
post #4 of 8 (permalink) Old 03-01-2014, 12:49 PM
dump the "voltage reduction units" if the LED's work on 12V and replace your flasher unit with an EP34 Electronic Flasher and you should be good.
post #5 of 8 (permalink) Old 03-01-2014, 07:26 PM
I was looking into LED's for tail and front blinkers. A lot of the info states they are not bright compared to incandescent bulbs. True?
smltownr is offline
post #6 of 8 (permalink) Old 03-01-2014, 07:57 PM
Kc2dgq manufactures LED replacements lights...plenty bright.
post #7 of 8 (permalink) Old 03-01-2014, 08:55 PM
2000 VN 750 Senior Member
/\ x2 KC2DGQ is the one with all the LED knowledge and he makes LED replacement boards for most blinker housings along with a few other items. If you have any questions he is the one to contact. The quality of his work for others is on the same level as he uses on his bike and that is something to see.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #8 of 8 (permalink) Old 03-02-2014, 02:23 AM Thread Starter
Big Nick's Avatar
The LED indicators I installed are very Bright and noticeable. I give them the vote of confidence, neat and effective.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
