Starting problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-20-2007, 06:53 PM Thread Starter
Starting problems
Hello all, I was reading about pick up coils because I'm having hot starting problems. I was wondering if anyone has come up with a procedure with pictures that I can use. Love the pictures!
I just lubed the splines (thanks to this forum I will not have to replace the shaft - it did need grease) and also replaced the fork seals using procedures posted here.
Thanks to the folks that took the time to write them up.
Vulcano
1990 VN750
Juarez, Mexico
Vulcano is offline
post #2 of 2 (permalink) Old 07-20-2007, 07:50 PM
Hot start seems to be a very common problem. Sometimes many things have to be done to fix it. The easiest fix that worked for some has been a new battery. They also recommend a sealed maintainence free battery.
vn750joe is offline
