Tachometer no workee - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 18 (permalink) Old 07-16-2007, 10:27 AM Thread Starter
Hey Gang,
I'm back, the bike is running, and I'm working on those last few niggling issues. Its an '85, so I guess that's to be expected.
The number one item on my hit list is that my tach doesn't work. When I'm riding, it will bounce every few seconds, but doesn't read. I plan on pulling the headlight and checking the connector, but is there anything else I should be looking for?
Thanks,
--Storm
storm16 is offline
post #2 of 18 (permalink) Old 07-16-2007, 10:45 AM
If you figure it out let me know, mine has a mind of it's own.
wwmkwood is offline
post #3 of 18 (permalink) Old 07-16-2007, 11:20 AM
Me thach no workee neither!
I have an 86. Tach doesnt work, but I dont think it's the connection because I "THINK" the temp gauge (part of the same unit) does work. Sometimes the speedo doesnt work, but if I tap the glass with my finger it'll start working. Tach is always unresponsive.
vn750joe is offline
post #4 of 18 (permalink) Old 07-16-2007, 12:11 PM
Joem's Avatar
I think these tachs are pieces of #*&%! Mine does not work either. Temp guage works, tach does not.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #5 of 18 (permalink) Old 07-16-2007, 12:21 PM Thread Starter
Really? My temp gauge doesn't work either. Blown fuse? (Fuel gauge doesn't work either, but I think that is the sensor in the tank.
--Storm
storm16 is offline
post #6 of 18 (permalink) Old 07-16-2007, 01:01 PM
"ya can't live forever"
artman's Avatar
Check the contacts in the ignition switch, they may be corroded etc.
The switch also has a spring loaded bb sized bearing and sometimes the spring gets too soft to maintain the contact.
Ivan Ramirez likes this.
artman is offline
post #7 of 18 (permalink) Old 07-18-2007, 06:31 AM
My tach started going crazy a while back. I had a whole load of other problems though like the bike would chug a lot as if it was running out of fuel but it was back firing like crazy.
Turned out my R/R was fracked. Replaced it with an electrex one and now the bike runs sweet again.
[edit] except that on Monday, some @!~# stole one of my rear shocks!
scot_vulcan is offline
post #8 of 18 (permalink) Old 11-14-2007, 10:15 PM
Vulcan Bobber
aminjuez's Avatar
I have an 89. Tach and Temp doesnt work, they have lights but doesn't mark anything, Please somebody can HELP me??? How can I make the troubleshooting for this???
aminjuez is offline
post #9 of 18 (permalink) Old 11-15-2007, 06:20 AM
Have you checked that any and all wire connections are clean and tight?
Temp could be a bad sensor. The tach, I'm pretty sure, works off one of the coils. Might be a bad connection there?
post #10 of 18 (permalink) Old 11-18-2007, 04:34 PM
Vulcan Bobber
aminjuez's Avatar
Ok, but how can I make sure it's a sensor?
aminjuez is offline
