Compatable Speedo? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 02-11-2014, 12:17 PM Thread Starter
lVluffin's Avatar
Compatable Speedo?
I'd like to give these bulbous gauges a slimming, especially if I plan to switch to clubmans, but I'm not sure if this is applicable:
ebay.com/itm/171231326652?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
Or if I must go retro with a single speed/voltmeter combo.
Sorry, I can't post links. -__-
lVluffin is offline
post #2 of 25 (permalink) Old 02-11-2014, 03:17 PM
Where do you connect the speedo? Or do you have to run something else to the tire? It's cool looking. I'd change mine perhaps if it works.
post #3 of 25 (permalink) Old 02-11-2014, 03:30 PM
those typically use a magnetic sensor that gets mounted to the fork, with a magnet on the wheel someplace. then you go program in how many revs=mph (method for that varies, from actually running at a certain speed, to entering the wheel circ.)
I had toyed with the idea for a while, but decided I had better things to spend my money on at the time
michiganteddybear is offline
post #4 of 25 (permalink) Old 02-11-2014, 03:31 PM
Dr. Vulcanstein
jadabull's Avatar
X2
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 25 (permalink) Old 02-11-2014, 03:37 PM
I don't wear em myself.I look kinda goofy in a speedy
post #6 of 25 (permalink) Old 02-11-2014, 03:46 PM
Dr. Vulcanstein
jadabull's Avatar
No, you just ride with your assless chaps, lol.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #7 of 25 (permalink) Old 02-11-2014, 04:12 PM
What am I the only one? Was wondering why I chafe after a long ride
post #8 of 25 (permalink) Old 02-11-2014, 04:29 PM Thread Starter
lVluffin's Avatar
Running the magnet wouldn't be that bad, its the wiring that I'm worried about. I haven't delved into the electronics yet, so I don't know if its plug and play, or if I'm going to have to ghetto rig it in there. Any idea if those wiring harnesses are appropriate?
lVluffin is offline
post #9 of 25 (permalink) Old 02-11-2014, 05:13 PM
usually only wiring that will apply to our bikes is:
power (usually 1 switched 12v, 1 constant 12v, one ground)
tach 1 wire
turn signal indicators (1 wire each direction)
Neutral indicator (1 wire)
high/low beam (1 wire)
oil light (1 wire)
those are the major ones (and they may vary depending on the unit)
some also have gear position indicators, which may be calculated by rpm/speed input, or some have actual inputs from switch(s).
basically, NONE will be plug and play on our bikes. we dont have the electronics in them to make that even remotely an option. Newer computer controlled bikes may have that ability, but usually a universal cluster like that will require connecting wires to various others that exist on the wiring harness
post #10 of 25 (permalink) Old 02-11-2014, 06:35 PM
A former member on here used that same speedo set up... he had to dissect the stock wiring harness in the headlight bucket to get the correct feeds for the sensors... It wasn't that bad (I helped him trace wires by phone) the hardest part of the ordeal was having the patience to track down the needed wires.
