Battery Question (MF) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-10-2007, 11:10 AM Thread Starter
Hey, I really wish I had spent more time reading on this site before I started to ride my vulcan (1994 750)!! I was having one hell of a time getting her started after I would pull up to gas stations and it would sometimes die on me when I pulled up to a light and let my rpms drop. First I found that I had two bad plugs, and then I went out and bought a replacement batter (again before I found about the wonders of the MF battery). I had the new battery in for A day and it died on me TWICE!
I was totally ticked and went out yesterday to buy a MF battery after spending a good bit of time reading all the testimonials about how much better they were - BUT the store didnt have Wesco or Yasusa. I bought a 12V AGM YTX14-AHL-BS battery with the part number CYLA14AHLBSXTA from batteries Plus. Does anyone know anything about these? Is this battery just as good? They guy at the store said I could return it and he would order me a Yasusa one, but I was in a hurry to get riding again.
THANKS!
Tim
Tybalt is offline
post #2 of 11 (permalink) Old 07-10-2007, 12:31 PM
Someone else here mentioned getting a battery from Batteries Plus.
Don't recall hearing of them having a problem with it.
I was going to get one from them, but still haven't yet
I did just do a search, and found one mention of a bad battery from B.P.
But that has happened even with the top brand ones. Brand new batteries can be bad from the start, no matter who the manufacturer is.
The B.P. ones do have a one year warranty.
post #3 of 11 (permalink) Old 07-10-2007, 12:40 PM
Geek
rnewell's Avatar
If your new battery died in one day you could have charging problems, or bad connections.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #4 of 11 (permalink) Old 07-10-2007, 12:45 PM Thread Starter
I got 2 new ones. The first one was a regular one that died - I think it lost some water, the other new one was the MF battery - it has worked well so far, but thats only one ride... I hope it continues!
Tybalt is offline
post #5 of 11 (permalink) Old 07-10-2007, 01:52 PM
BigT's Avatar
Hopefully all is well with the new MF battery. If for some reason you find that you're still having problems, this site is a God send for helping diagnose any problems that you may have. There is a wealth of information in the verses and folks here that know their s#!* when it comes to our bikes.
I had charging issues with mine when I got it and started with the MF battery. That didn't solve my problems, but with the help of this site I found the culprit, was able to get it fixed and have had no problems since.
Good luck.
I smile 'cause I don't know what the h*ll is going on.
BigT is offline
post #6 of 11 (permalink) Old 07-10-2007, 01:57 PM
Now what
Ironman's Avatar
YTX14 is the description that Yuasa uses on the battery that has their name on it so it's a good chance it's made by Yuasa and sold by Batteries plus. If you have to add the acid to the battery, that's another sign it's actually a Yuasa. First step is to take the battery to another battery shop and ask them to load test the battery. That will tell you if the battery is ok or not. Even new batteries can be defective. If the battery is good follow the electric fault finding chart on this site. http://tinyurl.com/c2zou Scroll down and you'll see the link.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #7 of 11 (permalink) Old 07-10-2007, 02:56 PM
93VN750's Avatar
I've got the BatteriesPlus you mentioned in my 750. Very good AGM MF battery, it will do you well.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #8 of 11 (permalink) Old 07-10-2007, 08:36 PM
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Curious as to how long a MF battery will last ?
"When the sun's comin' up,
I got cakes on the griddle.
Life ain't nothin' but a funny funny riddle,
Thank God I'm a Country Boy!"
norsseman is offline
post #9 of 11 (permalink) Old 07-10-2007, 08:38 PM
93VN750's Avatar
Lots of variables there, but under good conditions, 2 - 3 years.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #10 of 11 (permalink) Old 07-11-2007, 05:53 AM
2FAS4U
I have the Batteries plus one in mine. I had trouble with it after about 11 months. At that time it had a 1 year warranty, now the Mgr tells me they have a 6 month. He took care of me though.
2fas4u is offline
