LED conversion for turn signal lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-10-2007, 11:35 AM Thread Starter
Drive less, ride more...
theauhawk's Avatar
What dual-load equalizer make/model is recommended for our bike to convert the turn signals/running lights to LED bulbs?
Is there a thread somewhere else on the forum where I missed this--or other info on this conversion?
Thanks!......
theauhawk is offline
post #2 of 7 (permalink) Old 07-10-2007, 11:38 AM
I would like to know also that would be great
Thanks
KENNETH FORTUNE is offline
post #3 of 7 (permalink) Old 07-10-2007, 09:38 PM
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Someone's signature has LED tun signals listed, hope he can chime in here and give us a hand.
"When the sun's comin' up,
I got cakes on the griddle.
Life ain't nothin' but a funny funny riddle,
Thank God I'm a Country Boy!"
norsseman is offline
post #4 of 7 (permalink) Old 07-10-2007, 09:49 PM
93VN750's Avatar
I believe that you can get an LED flasher module to replace the Kaw unit, and that's all you need. Must replace all four t/s bulbs or fubar.
Some good reading (and products) here http://www.customdynamics.com/led_mo...hting_faqs.htm.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 7 (permalink) Old 07-11-2007, 05:04 AM
I think it might have been Hizzo (where is that guy???) that mentioned awhile ago, that a heavy duty flasher unit will work when going to LED signal lights, but I don't know if it will or not.
post #6 of 7 (permalink) Old 07-11-2007, 09:08 AM
93VN750's Avatar
Good point, where is Hizzo?
I don't think an HD flasher will work with LED's either. Problem is, the LED's draw so little current that the system thinks a bulb is out an flashes fast to tell you there's a problem.
Need an LED specific flasher or load balancer.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #7 of 7 (permalink) Old 07-11-2007, 09:40 AM
Benjammin'
BSkaggs513's Avatar
When I thought I had problems with the breaklight LED making my blinkers flash wierd (it actually didn't), I was forced to look into troubleshooting it. The Clear Alternatives site mentioned adding a flasher unit for LED bulbs. There is actually a flasher to work with LED blinker bulbs- it is referred to as a variable load flasher.
The following link is where bulbs can be purchased for the blinkers (about half way down the page);
http://www.sharperobjects.com/ledaccessories.html
They mention the need to add a variable load turn signal blinker which I believe is this unit;
http://www.autobarn.net/variableflasher.html
Actually, the sharperobjects.com site has something called a "dual load equalizer" for blinker LED's. It does not look like a round flasher, so I am not sure where (or how) it would mount.
I have not ordered or installed any of the parts above. I think they will need to be discussed and approved by this group before I place any order!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
