Signals won't blink!!!!! NEED HELP!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 07-06-2007, 10:13 AM Thread Starter
93 vulcan 750 that has signal lights that do not flash. turn on but do not signal. Please help!!!! Anybody have an idea of what might cause this. Maybe a relay, or bad switch. Any takers????
shaf650R is offline
post #2 of 13 (permalink) Old 07-06-2007, 12:15 PM
My first guess would be the turnsignal relay.
It's to the rear of the battery box.
post #3 of 13 (permalink) Old 07-09-2007, 08:47 AM Thread Starter
Thanks for the advice I will start there
shaf650R is offline
post #4 of 13 (permalink) Old 08-25-2007, 10:02 PM
So was it the relay?
holyman is offline
post #5 of 13 (permalink) Old 08-26-2007, 11:03 AM
I am guessing that it is the what most call the blinker switch. The one that makes the blink sound.
post #6 of 13 (permalink) Old 07-09-2010, 08:08 PM
PoggiPj's Avatar
Send a message via AIM to PoggiPj
Today my flashers stopped working too. The fronts light (running light) mode, but will not flash. I've replaced all 4 flashers with LEDs, and changed out the relay some time ago. I suspect it died.
Regards,
Pete in Gaithersburg, MD
1996, 6,000 miles
Relocated R/R, Corbin seat, Plexifairing III, Sunpro Voltmeter, Sears MF.
Xelement X840 Saddlebags
PoggiPj is offline
post #7 of 13 (permalink) Old 07-09-2010, 10:20 PM
umm poppi... how long after you did the LED conversion did the blinkers stop working?
post #8 of 13 (permalink) Old 07-09-2010, 11:50 PM
PoggiPj's Avatar
Hi Slim! It's been awhile. I changed them over to LEDs about 18 or more months ago. They were working fine up until today. I'm just about to go out there and trace voltage. I can't figure out which fuse they're on.
Regards,
1996, 6,000 miles
PoggiPj is offline
post #9 of 13 (permalink) Old 07-09-2010, 11:52 PM
they are on the same fuse as the Tail Lights... IIRC... one sec while I look it up... I was wrong.. Main fuse...
Name:	Turnsignal Ciruit Wiring Diagram.jpg
post #10 of 13 (permalink) Old 07-10-2010, 12:30 AM
PoggiPj's Avatar
Well, i just bypassed the relay, and the signals light up just fine. So, I guess it's time to replace the relay.
Regards,
1996, 6,000 miles
PoggiPj is offline
