gaskets and seals for stator replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 01-29-2014, 06:02 PM Thread Starter
looking to order parts...am i missing anything
11060-1086 GASKET,GEAR CASE 1
11060-1089 GASKET,GENERATOR COVE 1
92051-005 OIL SEAL,TB13225.5 1
92055-049 "0" RING,31MM 1
92055-109 "O" RING,DYNAMO COVER 1
92055-1308 RING-O,19MM 4
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #2 of 11 (permalink) Old 01-29-2014, 08:41 PM
The tiny "o" rings for the outer cover I get from the hardware store for $0.12 each...I bet all ya really need are the cut gaskets....
post #3 of 11 (permalink) Old 01-30-2014, 01:39 AM
Ndr
If you're pulling the engine to do the replacement, might be worth doing your balance dampers at the same time. Worth the $40 or so for the insurance of not having them go out on you later and either having to pull the engine, or have major damage to the engine.
Ndr is offline
post #4 of 11 (permalink) Old 01-30-2014, 10:16 AM
x2 !
post #5 of 11 (permalink) Old 01-30-2014, 02:07 PM Thread Starter
How many miles do they last? Do i need to split the cases to do so?
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #6 of 11 (permalink) Old 01-30-2014, 03:08 PM
No you don't have to split the case they are right behind the large stator cover
The balancers have been known to fail unexpectedly... at various mileage. some have failed with around 2000 miles, while others lasted 20,000 miles. we recommend changing them out when doing a stator for a piece of mind. 30 bucks in parts no, or several hundred bucks for a new engine later
post #7 of 11 (permalink) Old 01-30-2014, 04:42 PM Thread Starter
Might as well do it then, maybe ill do the stator mod plate since the cover has to come off
Thanks guys
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #8 of 11 (permalink) Old 01-30-2014, 04:56 PM
i would do the stator mod at that point to... makes sence
post #9 of 11 (permalink) Old 01-30-2014, 07:45 PM Thread Starter
Magneto Flywheel Puller 4452012
GASKET,GEAR CASE 11060-1086
92051-005 OIL SEAL,
92055-1319 RING-O
92075-1747 DAMPER
92075-1748 DAMPER
parts are ordered, 108.00 shipped
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #10 of 11 (permalink) Old 02-03-2014, 05:45 PM Thread Starter
showed up today, mailed it a week ago saturday to tpe and its here
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
