I believe my starter button just needs the contact cleaned. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-26-2014, 07:21 PM Thread Starter
son-of-fire's Avatar
I want to get into the starter button and clean it but I can't get the fool thing off the handlebar because of the throttle cables. how do I get this thing off? I'm assuming I need to loosen the cables but I'm not exactly sure what I'm doing.
Here's pictures of what I'm looking at.
1993 Vulcan 750 "Sookie"
1980 KZ750 LTD (Project) "Saki"
2007 Honda Rebel (Sold) "Lucky"
son-of-fire is offline
post #2 of 6 (permalink) Old 01-26-2014, 10:02 PM
YOu need to pull the plastic neck covers off just in front of the gas tank, and possibly lossen the gas tank at minimum to get to the little brass collored hoom that keeps the throttle cables clamped to the frame. then you should have enough play to pull the throttle housing off the bars.
post #3 of 6 (permalink) Old 01-26-2014, 10:59 PM
Use either rubbing alcohol or CRC 3-36 (like 5-56 but for electrics) to clean stuff....TV Tuner cleaner works too....
post #4 of 6 (permalink) Old 01-27-2014, 04:17 PM Thread Starter
I'm not sure which plastic neck covers you're referring to? Sorry. I'm kinda dumb here, and I didn't think that getting to the start button was gonna be difficult at all. I've tried searching but haven't found anything showing how to take the throttle piece off. Is there anything you know of? Preferably with pictures?
Thank you I will.
post #5 of 6 (permalink) Old 01-27-2014, 04:25 PM
Thank you I will.
directly in front of the tank you will see a black plastic piece with a reflector on it that is the neck cover there are two phillips head screws holding each side on and they click together at the top
post #6 of 6 (permalink) Old 01-28-2014, 12:59 AM
'03 VN750 "Rosie"
bstew7890's Avatar
All I did was loosen the cable adjusters at the upper end of the cables to create some play, then slip the ends off the throttle. Be careful taking the button apart and note carefully which way the spring sits inside. Putting it back together is awkward.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
