Side stand switch, 2 earths? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 12-31-2013, 01:25 AM Thread Starter
Big Nick's Avatar
So I Imagined the side stand switch was supposed to do something, But after testing I found both the BLK/Y and the BLU/WHT, are active earth's coming from the harness. I know the BLK/Y is an earth, can I assume, there has been some miss connection in the junction box? Or elsewhere?
I had a look at the break down of the fuse box and it mentions a diode for safety devise. What's that mean? What's a diode?
Next question if the diode connected to the side stand switch is broken, and it stops engine from operating, can I add a relay to the power side of the coils and have the bike run?
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Last edited by Big Nick; 12-31-2013 at 02:36 AM. Reason: More description, and grammar repair.
Big Nick is offline
post #2 of 18 (permalink) Old 12-31-2013, 02:31 AM
Dr. Vulcanstein
jadabull's Avatar
Originally Posted by Big Nick View Post
So I Imagined the side stand switch was supposed to do something, But after testing I found both the BLK/Y and the BLU/WHT, are active earths coming from the harness. I know the BLK/Y is an earth, can I assume, there has been some missconnection in the junction box? Or elsewhere?
I had a look at the break down of the fuse box and it mentions a diode for safety devise. Whats that mean? Whats a diode?
I'll have to take a look at my wires to know exactly what your talking about, unless someone else chimes in first, but a diode is an electronic device that will only allow current to flow in one direction only.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 18 (permalink) Old 12-31-2013, 06:47 AM
That kickstand safety switch can be disconnected if its causing problems... I don't have the wires in front of me or I'd have a definite answer for you.
post #4 of 18 (permalink) Old 12-31-2013, 09:09 AM Thread Starter
Big Nick's Avatar
Thanks for the tip JadaBull.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #5 of 18 (permalink) Old 12-31-2013, 09:25 AM
If the bike is in neutral, both wires will be grounded, if the bike is in gear, only one wire will be ground.
post #6 of 18 (permalink) Old 12-31-2013, 11:12 AM Thread Starter
Big Nick's Avatar
The ignition circuit Trace, tomorrow!
Starting with W/R at the fuse box,through the fuse to W up to the ignition, then Y from ignition through 6 pin connector, becoming Y/R through 6 pin connector, to kill switch, then to start button and coils. Me think it Mazing! My last couple of bikes, Magneto and volt pack equip t, had very few wires.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #7 of 18 (permalink) Old 12-31-2013, 11:15 AM Thread Starter
Big Nick's Avatar
Side stand.
Hi Slim, yep it's in neutral, should these wires be connected or separated to do away with the side stand switch?
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #8 of 18 (permalink) Old 12-31-2013, 03:59 PM
connected but if you do so and all other switches are working then the bike will only start in neutral with the clutch released
post #9 of 18 (permalink) Old 12-31-2013, 09:26 PM Thread Starter
Big Nick's Avatar
More electric mods.
So the next thing after the side stand, is the Clutch lever isolator switch. I can see myself at some stage, snuffin it it traffic and fumbling for neutral to start it, hence the next mod.
I wonder if anyone ever bolted a Joh Hunt, on one of these bikes?
Thanks for the help guys.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #10 of 18 (permalink) Old 12-31-2013, 09:46 PM
You mean a Joe Hunt magneto ?....would be cool, but I think he only makes em for HD and Brit bikes...used to anyway...mebbe he does Jap now too....if so, Im "sure" one of them could be made to "work".....*weg*....
