2 spare wires near igniter? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 12-22-2013, 06:52 AM Thread Starter
Big Nick's Avatar
The loom that feeds my igniter on my 86 VN has a twin female connector taped into the black and yellow wire,that goes to the igniter. I also have a white/lt blue wire with a twin female connector spare from the same loom. I have a Kawasaki Manual but I need A microscope to see it. I suspect the black/yellow join is some kind of previous attempted repair, not in use, so I might remove it. The White/lt blue looks factory and is a worry. Anyone know what it or they are for?
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 5 (permalink) Old 12-22-2013, 09:30 AM
1/4 Female spade connectors on the ends? if so they are your accessory wires, not used, they are there for hooking up exactly that accessories
post #3 of 5 (permalink) Old 12-22-2013, 12:29 PM
yup and they have constant power from the battery so what ever you hook into them needs a switch on it unless you want it to have constant power
fyi there is another set of wires for the same purpose inside the headlight bucket
post #4 of 5 (permalink) Old 12-22-2013, 07:56 PM Thread Starter
Big Nick's Avatar
connectors
The connectors I have are twin female bullet type, but just the same I'll tape them off and test them at a later date.Thanks.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
post #5 of 5 (permalink) Old 12-23-2013, 02:51 AM
yup still acessory leads
