Frozen Outer Stator Cover Bolts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-15-2007, 07:44 AM Thread Starter
Crobins365's Avatar
Angry Frozen Outer Stator Cover Bolts
Am I the only one that can't get the outer cover off of the stator cover? The ()&@$#%_ phillips head screws - true to form - are absolutely frozen in place. I've splooted 'em with PB Blaster, backed that up with acetone, put a screwdriver in the slots and tapped them with a hammer...no movement at all, even with an electric drill on low power (high torque). The flame thrower (propane torch) will be next, but is there a secret to these that I'm missing? Thanks in advance!
C
Crobins365 is offline
post #2 of 12 (permalink) Old 06-15-2007, 08:01 AM
Have you tried the thingy that has attachments with philips and straight heads that you smack with a hammer on the end? They are great tools for breaking loose screws.
dogedog is offline
post #3 of 12 (permalink) Old 06-15-2007, 09:16 AM
An impact driver.
post #4 of 12 (permalink) Old 06-15-2007, 09:33 AM Thread Starter
Crobins365's Avatar
I just tried a phillips head screwdriver and a mallet, with some sharp taps on the end of the screwdriver. Even tried tapping the screws from the back side. I noticed TOC replaces the Phillips heads with hex bolts. Maybe - if I get them out - I'll replace 'em.
C
post #5 of 12 (permalink) Old 06-15-2007, 05:16 PM
if you don't have an impact, try using a big screwdriver and use both hands on it and turn with all your might while a (trusted friend) hits the end with the hammer.....you might want to have another hammer handy in case the friend misses lol once you get them out I would definitly use hex bolts....good luck
TrashLord is offline
post #6 of 12 (permalink) Old 06-15-2007, 07:44 PM
wait duhhhh I'm tired....take a vise grip and put it on the screw driver....push in on the screw driver and turn the visegrips walla its off
post #7 of 12 (permalink) Old 06-15-2007, 10:12 PM
An impact driver is a valuable tool--select a bit that fits correctly and hit. Wouldn't work on a bike without one. $15-$25 at most auto stores. You can probably find a cheap one @ harbor frieght.
http://www.harborfreight.com/cpi/cta...emnumber=93481
Like this but in 3/8" drive. And this is the only one HF stocks. JC Whitney will have them as should pep boys and checker auto.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #8 of 12 (permalink) Old 06-16-2007, 07:38 AM Thread Starter
Crobins365's Avatar
Huh. I guess I don't have to endanger my screwdrivers after all! Thanks, folks. Michael ...I'm not understanding the vise grip description you offered.?? Perhaps I should JB Weld the vise grip to one of the screws, then turn? Seriously, though, can you explain again? Thank you!!
C
post #9 of 12 (permalink) Old 06-16-2007, 11:33 AM
Cindy, take your vise grips and clamp them firmly to the screw driver (in a 90 degree angle) this will act like a handle and as you push in on the screw driver hard, you can turn the visegrips with your other hand......just be sure the screw driver you use fits into the screw firmly. I've used that method many times before......everytime I say "dam I need an impact driver" but like everyone else has said...an impact driver is a valuable tool to have
post #10 of 12 (permalink) Old 06-16-2007, 11:45 AM Thread Starter
Crobins365's Avatar
Got it, thanks! I was just at Home Despot and found an impact driver there, so now I'm gonna go look for something to rip open...
C
