VN750 Stator Replacement Notes - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 86 (permalink) Old 11-20-2005, 05:43 PM
Forum Faciliator
Red Baron's Avatar
Re: VN750 Stator Replacement Notes
Originally Posted by Dianna
..snip.. I also replaced the inner stator cover with the one from TOC Manufacturing so when it come time to do it again.. 20,000-50,000 miles down the road hopefully. I will only have to pull the outer cover
http://www.tocmanufacturing.com/Side_Cover_mod.htm
Well I just put my bike up for winter or the next three months whichever is shorter...;-). I have 15,100 miles on my electrex stator using the TOC cover, so it is working just fine. FYI the OEM stator went at 10,700 miles.
Red Baron
Binghamton, NY
Alright Already, Lets Ride!!
Red Baron is offline
post #12 of 86 (permalink) Old 03-08-2007, 03:43 PM
Jaymann
I'm new to the site and to riding. I have just purchased a '99 750 with 1,900 miles on it. Since on the site I'v read alot of comments about failed
STATORS. What is this part? What does it do and why does it fail? Is there anything to do prior to it failing to prevent it? Should it be replaced at a certain milage? What's up with this thing. PLease give me the scoop. I have a Clymer repair manual and I'm having trouble finding it in the book. Please help with some info . Thanks
Jeff
jaymann is offline
post #13 of 86 (permalink) Old 03-08-2007, 04:16 PM
HAWK
Ccspinner's Avatar
The Stator is like a altornator for a car, There is no real way to prevent one from going and no set milage for a fail. You can help by not overloading the electrical system, moving the R/R to a cooler spot and replacing the BAtt with a MAint free one.
Good Idea to check and keep clean all the electrical connections
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #14 of 86 (permalink) Old 03-08-2007, 04:21 PM
93VN750's Avatar
Jeff
Jeff -
Clymer's refers to it as the alternator.
Get a AGM, maintenance free battery ASAP if you don't already have one.
Get a voltmeter connected to the battery terminals. Should read about 13Vdc at idle, and go up to at least 14 Vdc by 3 - 4K rpm. If not, there is a charging system probelm somewhere.
But battery first and voltmeter first.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #15 of 86 (permalink) Old 03-08-2007, 04:23 PM
fergy's Avatar
It's hiding under the left engine side cover, which you can't remove without unbolting the engine and tilting it to the right.
Aside from what Chad said about prolong it's life, keep your oil clean and full, as your oil is all it gets to cool with, maintain your cooling system, don't let your bike overheat and try to avoid a lot of hot weather bumper to bumper slow traffic. Heat kills the stator.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #16 of 86 (permalink) Old 03-08-2007, 04:36 PM
Thanks guys...BIG help. I'll look into all the suggestions.
jaymann is offline
post #17 of 86 (permalink) Old 06-10-2007, 05:08 PM
Allan, great post.
Pictures very helpful.
Why did you tie down the forks and center stand?
Can't figure that one out.
Thanks again.
Stewart
Stewart Traill is offline
post #18 of 86 (permalink) Old 06-10-2007, 10:25 PM
Thanks again.
Stewart
That's to make sure there is NO chance of the bike coming down off the centerstand.
The rope is through the front wheel, then around the centerstand, basically locking it in the down position.
post #19 of 86 (permalink) Old 08-21-2007, 04:04 PM
Lots of good info here. I need to replace the stator on my 93 VN750. I have Clymer's book and data from here, but no garage :-( so i'm a little weary of taking my bike apart outside. But I can't afford to pay the $900 estimate I got for Parts & Labor.
paganbaby is offline
post #20 of 86 (permalink) Old 04-13-2008, 09:13 PM
On His Lady Vulcan
wkrizan's Avatar
I hear you there, that is a pretty steep price to pay for a repair that can be done by yourself easily enough as long as you take your time and DON'T rush it. What I would suggest for the "no garage" problem is go online to a site like craigslist.com for your area and look for one of those Costco garages thingy's. They are cheap enough at costco already but a used one would be even cheaper I am guessing. keep it covered and closed to deter any unwanted critters. Just my 2 cents worth.
wkrizan is offline
