No turn Signals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 11-09-2013, 03:25 PM Thread Starter
No turn Signals
Turn signals stop working mid-ride this morning. (40 degrees....brrrr)
Headlight (Hi & Lo beam) works....Hi beam indicator works
Tail light works
Removed seat....Checked all connections....good
Opened headlight....Checked all connections....good
Checked fuses....good
Bike never in rain....garage kept.
Running out of ideas.
Anyone aware of in-line fuse for signals?
Any other suggestions are welcome
VoIPDoc is offline
post #2 of 9 (permalink) Old 11-09-2013, 03:45 PM
Tail light works
A broken wire / connection @ the switch (possibly ground), in a inline connector @ the frame neck or connection @ the Blinker Stadt.
hope this helps
post #3 of 9 (permalink) Old 11-09-2013, 04:23 PM Thread Starter
I think I found the problem......Flasher relay just behind the battery.
Flasher Relay PN: FA249ED.....anybody know where I can buy it or if it can be tested??
VoIPDoc is offline
post #4 of 9 (permalink) Old 11-09-2013, 04:45 PM
I would think most Auto Part Stores would be able to cross that part number.....fix ya right up.
post #5 of 9 (permalink) Old 11-09-2013, 05:22 PM
EP34 flasher relay...get the electronic one or "variable load type" so that if you decide to eventually go to LED you are all set.
post #6 of 9 (permalink) Old 11-10-2013, 01:10 PM
Would be helpful if you tell us what year your bike is. Older ones had the self canceling signals ... which sometimes screw up too.
post #7 of 9 (permalink) Old 11-10-2013, 02:14 PM
Are they plug and play for our bikes?
post #8 of 9 (permalink) Old 11-10-2013, 03:53 PM Thread Starter
Resolved!
Replaced flasher relay with EP34
Thanks for the suggestions
KM, 2006
VoIPDoc is offline
post #9 of 9 (permalink) Old 11-10-2013, 07:19 PM
yes!!
better late than never
For those of you who are contemplating LED blinkers (see my signature), the EP34 is a plug and play replacement for our flasher relay. If you find one make sure it is ELECTRONIC and says VARIABLE LOAD type or similar to ensure it works for lower current draw lighting such as LED's.
