wire harness idea for stator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 11-07-2013, 01:49 PM Thread Starter
emtdon's Avatar
wondering if this would be a good idea to connect stator wires. or if anyone has used a harness to connect the wires. seems like it would be good since it is waterproof
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 4 (permalink) Old 11-07-2013, 02:11 PM
The best option is to SOLDER the wires and heat shrink them.
The heat generated in the contacts seems to be the reason some connectors get hot and actually melt. ANY PIN or BULLET connector will not be a perfect connection, so they are prone to generate heat.
If you leave the stock bullet connectors on the wires, it is best to NOT bunch themtogether so they don't get hot and melt which could cause them to short together.
post #3 of 4 (permalink) Old 11-08-2013, 03:02 AM
I agree with the solder and heat shrink method. I found my wires has overheated at the factory connectors and turned brittle. One of them broke while I was trying to unplug it. I cut out the connectors, and soldered them together. Been fine ever since. I believe those stock connectors are the cause of a lot of stator failures, because they get loose, and develop high resistance, which causes both the wires and the stator to overheat. I prefer connections that are not likely to develop high resistance. Soldering all the wires in the charging system is common practice with older Goldwings.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 4 (permalink) Old 11-08-2013, 05:39 AM Thread Starter
emtdon's Avatar
thanks, i thought it looked like a good idea but was worried about the wires getting to hot and melting the plug. i will go with solder and heat shrink.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
