All lights flicker when either turn signals are on - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 11-01-2013, 01:55 PM Thread Starter
New to this forum - wished I found this before i started working on the bike. Wifes 92 750 - replaced the stator and the mechanic said the wiring might be a problem. Looks like the PO made a couple of modifications one of which was paring down the wiring. The mechanic that replaced the stator pulled all the wires. I replaced the wiring harness, ic ignitor, reserve lighting unit and JB. All the connectors on the bike were clipped so I reconnected using bullet with heatshrink. Got all the wiring done but now have 1 small problem. All the lights flicker when either turn signal is on. Any thoughts?
allofus427 is offline
post #2 of 13 (permalink) Old 11-01-2013, 02:09 PM
first thought.....
Clean all your grounds, particularly each light and ALL Junction (Fuse) Box connections.
hope this helps
EDIT: Junction Boxes have given problems in the past.
post #3 of 13 (permalink) Old 11-01-2013, 02:33 PM
most brands of stators are crap for these bikes you could be not getting enough voltage at idle do the lights flicker when you raise the rpms up?
post #4 of 13 (permalink) Old 11-01-2013, 04:51 PM
first things first....check your battery voltage.
With the bike off, you should have 12.5V and it should rise up to around 14.5V or even higher with the engine revving over 3K.
if that isn't happening, then the charging system is weak....could be an inferior stator or a bad Regulator/Rectifier.
check your grounds and battery connections.....including the frame and engine ground straps......Don't just look at them or tighten them.....remove them to clean them....then use dielectric grease to protect them before tightening them back down.
pull your fuses and reseat them....just to be sure.
See what you get from doing these simple things...then report back before you go digging into the harness any deeper.
post #5 of 13 (permalink) Old 11-02-2013, 01:23 AM
X2 what Kc said .a weak battery in a vn will do weird things.
post #6 of 13 (permalink) Old 11-02-2013, 01:18 PM Thread Starter
Thanks - Things are starting to make sense - the battery was on the charge - I will be cleaning all connections and using the dielectric on all of the connections. Should I use it on the bullets that I put in as well? I will be posting pictures of the other modifications that were done for advice on those.
post #7 of 13 (permalink) Old 11-02-2013, 11:05 PM
If you look at the wiring diagaram too, you'll see that a lotta stuff is linked together.....check all yer bullet conections.....I mean ALL....get a good diagram and run em all down....thats usually the culprit....many of us have eliminated those connectors and just did straight solders....
post #8 of 13 (permalink) Old 11-10-2013, 01:51 PM Thread Starter
Ok will be heading back to the bike in the next day or 2. The question I have is the connections to the coils, does it matter what color goes to what side on the coil. The diagram just shows the colors but not the specifics.
post #9 of 13 (permalink) Old 11-10-2013, 02:08 PM
No, does not matter.
Coils are not Polarity Specific.
post #10 of 13 (permalink) Old 12-04-2013, 02:34 PM Thread Starter
UPDATE - New Battery has taken care of the lights, we connected the coils and have spark. Exhaust system is re-attached. Will post pictures of what was added/removed when I am home. Next is to make sure it runs and is charging correctly.
