frustrated - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 10-27-2013, 09:16 AM Thread Starter
frustrated
i just finished puting a stator and pulsing coils in and i know the pulsing coils are in corret black and red on top but i go to start it and it will only run with the starter switch pushed as soon as i let go it stops running please if anyone has had this problem or any idea of what it is please let me know.
john
jbh012367 is offline
post #2 of 13 (permalink) Old 10-27-2013, 11:11 AM
I had this same problem... but for the life of me, I can't remember what it was... I think it had to do with the safety switches not being hooked up.
post #3 of 13 (permalink) Old 10-27-2013, 11:19 AM
I recall this problem being solved in the past year, but don't recall whom or what fixed it.
Searched and found one old thread from 2008 where the owner installed a toggle switch. He would start the bike, hold start, then open the toggle switch to get it to stay running. The most recent fix was simpler I believe.
It may have something to do with the safety switches and wiring.
Or maybe the kill switch?
Someone here fixed this in 2013. The problem I found in a search, nobody ever posted the solution.
post #4 of 13 (permalink) Old 10-27-2013, 11:22 AM
https://www.vn750.com/forum/gtsearch....x.php&ref=&ss=
That's the search I used here, start sifting or change the search terms and use fewer words? The answer is here somewhere.
post #5 of 13 (permalink) Old 10-27-2013, 01:34 PM
x2
It was suspected to be in the start controls, turned out to be in either the wiring harness (bad connector issue) or one of the relays.....
I cannot remember which for sure, but iirc a connector under the tank at the neck ?
hope this helps
post #6 of 13 (permalink) Old 10-27-2013, 03:11 PM Thread Starter
i did not disconnect any wires i didnt remove the engine i put a stator mod kit in and thats all does it matter the wiring of the stator i assumed not since they are all the same colour.
post #7 of 13 (permalink) Old 10-27-2013, 03:31 PM
Originally Posted by jbh012367 View Post
i did not disconnect any wires. i didnt remove the engine. i put a stator mod kit in and thats all. does it matter the wiring of the stator i assumed not since they are all the same colour.
Your assumption is correct.
post #8 of 13 (permalink) Old 10-27-2013, 05:33 PM
Big Nick's Avatar
u could try.
Hot wireing the coils and work back from there.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #9 of 13 (permalink) Old 10-27-2013, 07:43 PM
I know for sure, loose spade connectors in the Junction Box plugs can affect a lot of things, I tightened all of mine and fixed the fan.
Here's a thread from '08 that seems to indicate it was a fried Junction Box, see page two: https://www.vn750.com/forum/showthread.php?t=7490&page=2
From looking at his old posts, looks like he did get it going. Slim? Ring any bells?
A new search to sift through:
https://www.vn750.com/forum/gtsearch....152j6230528j12
post #10 of 13 (permalink) Old 10-28-2013, 02:13 AM
yes it does... Bulwinkle ended up sending me his JB for me to look into it more. I found two burnt safety switch diodes along with a bad relay (can't remember which one it was, but I am thinking Starter) Once I soldered in new relays and didoes the bike lived once a gain.
