Regulator/Rectifier interchangeability? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-19-2013, 10:15 PM Thread Starter
My bike died a fortnight ago and I thought my battery just went on me. It wouldn't hold any charge so i couldn't start my bike again.
Replaced the battery and it started right up but died shortly after. Upon closer inspection I saw that the regulator/rectifier was burned out. I mean, literaly partially melted and the connector was charred.
Anyways, I ordered a new R/R from Caltric online. I got the one specificially for the Vulcan 750.
3 days later the package arrives and it does NOT look like the one from my bike. The one I ordered was an exact match. The one I got, after going back online looks like the one for a yamaha.
My question is this, the bolts line up, the connector (replacing it) will fit and everything. Will the R/R for a yamaha bike work on ours?
I contacted Caltric and they haven't gotten back to me. But if an R/R is an R/R so long as its for a 12V battery I don't mind putting it in. It does fit afterall, just thought I'd ask for some opinions.
Thanks.
prophet is offline
post #2 of 7 (permalink) Old 10-19-2013, 10:21 PM
An r/r is not an r/r. Each motorcycle requires a different amount of amps to keep the battery charge. If the new regulator produces more than 30 amps, you will be good. If not then it probably won't be good for the stators.
post #3 of 7 (permalink) Old 10-19-2013, 10:46 PM Thread Starter
Slim,
I appreciate it. That's the kind of info I needed. Hopefully they can exchange it quickly without charging me shipping because that'll just piss me off.
prophet is offline
post #4 of 7 (permalink) Old 10-20-2013, 05:25 AM
no problem brother. you might look for a MOFSET R/R if you are willing to go to all that work to make a new harness.
post #5 of 7 (permalink) Old 10-20-2013, 10:11 AM
I'm not sure exceeding 30 amps is necessary for stator life, since the Shindengen MOSFET FH020AA kit comes with a 30 amp maxi fuse.
http://www.ebay.com/itm/FH020AA-Shin...9eeec4&vxp=mtr
I put one on my bike, it's doing fine and this one is being used on many VNs.
I was a little alarmed when it started putting out a steady 15v, then I found the loose battery cable.
post #6 of 7 (permalink) Old 10-20-2013, 10:37 AM
no Spock you miss understood me, i said under 30 amp.. over is ok.. I am running a 50 amp MOFSET but then again I also upped my electrical demands quite a bit too.
post #7 of 7 (permalink) Old 10-20-2013, 11:34 AM
Wink
Slim, I've been so out of it the past week, I almost agreed.
... If the new regulator produces more than 30 amps, you will be good. If not then it probably won't be good for the stators.
