is mosfet r/r required after tp stator? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-19-2013, 12:14 PM Thread Starter
emtdon's Avatar
I'm going to get a tp stator do i have to replace the regulator with a mosfet? i plan on doing this anyway but will be a while. i already have a new regulator so i didn't want to buy another one yet. thanks for any info. .
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 5 (permalink) Old 10-19-2013, 12:25 PM
No you don't have to do a mofset R/R when you do a TPE stator, or any other brand of stator.
post #3 of 5 (permalink) Old 10-19-2013, 12:28 PM
No, a mosfet R/R is not required....It does compliment the charging / electrical system, as does a AGM Battery.
post #4 of 5 (permalink) Old 10-19-2013, 12:32 PM Thread Starter
emtdon's Avatar
thanks, would i still be able to add a lightbar without killing the new stator?
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #5 of 5 (permalink) Old 10-19-2013, 03:28 PM
depends on how many watts the new light bar uses... Stock R/R is rated at under 20 amps which is 240 Watts, our bike uses almost all of it in the stock form. Even though you are going with a TPE stator, you will only get 20 Amps out of the charging system because the Voltage Regulator regulates it to 20 amps. the only way to get more power out of your charging system is to add a larger R/R. when you do upgarde to a MOFSET R/R, look into the fallowing models to scource one from.
Model / Output / Source Bike
FH001 / 35A / FJR 1300
FH008EB / 40A / BR 600 RR
FH010BA / 50A / ZX-10R
FH012AA / 50A / FJR 1300, R1
FH012BA / 50A / ZX-14R, ZR1400, GTR1400
FH014AA / 50A / CBR 1000 RR
FH016AA / 40A / ZX-6R
