battery not staying charged - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 10-16-2013, 02:42 PM Thread Starter
BeeSea's Avatar
ok not sure if I should suspect a bad stator or a bad battery or something else so reaching out to the community on this one...
My battery I just bought on line it's a closed case one, but when I got it and charged it -it kinda lost a little charge on the bench. (While I was waiting to get the bike back together-not a long time but maybe a month before I got it in the machine)
Now that it's in the machine it's not staying charged...How do I figure out if it's the battery or the stator? Or something else?
thanks-
BeeSea
BeeSea
1986 750 Vulcan
Relocate R/R to side cover
Re-did the engine
from the case up.(And it runs)
YOU CAN TOO!
BeeSea is offline
post #2 of 26 (permalink) Old 10-16-2013, 02:50 PM
Take the battery to Autozone and have them do a voltage and load test on the battery. If its good, you'll want to check your charging system on the bike.
Seems if it lost charge just sitting on the bench the battery has an internal short...
post #3 of 26 (permalink) Old 10-16-2013, 04:51 PM
I am assuming that when you say it is a sealed batttery, you are referring to an AGM type.
My experience with the AGM is that once fully charged, it will sit for months in a cold shed while installed on the bike over the winter and not leak down much at all.
They hold the charge well when everything is as it should be.
Even with a MOSFET R/R and some other small items suckig small amounts of power continuously, the batttery should not leak down in a few weeks.
Like KM said....have the battery load tested.
You can also use an ammeter in line with the positive lead of the battery to see if something is drawing current on the bike when the key is in the OFF position.
post #4 of 26 (permalink) Old 10-17-2013, 08:55 AM
waynebo37's Avatar
I purchased an AGM Battery for my son's Yamaha Maxim online and when I received the battery, it did not stay charged very long either. Like KM stated, take it to Autozone or NAPA and have it load tested. I did and it was the Battery. I called the online seller (I can't recall who it was for sure, but I think it was something Powersports) and they sent me a new one. The second one is still holdong a charge very well. I also had to replace the battery in my Vulcan and it has been a very reliable battery, bought from the same seller. You never know!! Good Luck!!
Wayne Manwaring aka: Waynebo37
Clarkston, WA
'01 Vulcan 750
F&S Extended Passenger Backrest
Memphis Shades Santa Cruz 'shield
Throttle Rocker
Vista Cruise Throttle Lock
Tourmaster Studded Slanted 'bags
Dianna Ride Bell
DeGoated, then ReGoated
K&N Air Filters
Custon VN Grille Guard
Misc. add-ons
waynebo37 is offline
post #5 of 26 (permalink) Old 10-17-2013, 01:45 PM Thread Starter
BeeSea's Avatar
Ill get a chance this weekend to get it load tested. Thanks for all the good info.
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #6 of 26 (permalink) Old 10-19-2013, 04:12 PM Thread Starter
BeeSea's Avatar
Well the battery tested good...guess its on to the stator....
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #7 of 26 (permalink) Old 10-19-2013, 04:30 PM
fallow the CS TS guide to a "t" make sure that the battery is fully charged before starting the test. then post the results back here in the same format that I wrote the chart.
CS TS Guide
post #8 of 26 (permalink) Old 10-20-2013, 05:18 PM Thread Starter
BeeSea's Avatar
My tester is OHM x1k so if it registered zero I was confident that the .034-.052 stuff was good...it goes 0 up to 1k but as you can see by the results something is wrong...what do these results tell me? (THANKS!)
Leg A1-A2 _____Ω 0.34-0.52 Ω good
Leg A1-A3_____Ω 0.34-0.52 Ω good
Leg A2-A1_____Ω 0.34-0.52 Ω good
Leg A2-A3_____Ω 0.34-0.52 Ω good
Leg A3-A2_____Ω 0.34-0.52 Ω good
Leg A3_A1_____Ω 0.34-0.52 Ω good
Leg A1-Ground_____Ω OL nothing registered no resistance
Leg A2-Ground_____Ω OL nothing registered no resistance
Leg A3-Ground_____Ω OL nothing registered no resistance
R/R Static Test:
A1-A2__________Ω ∞ good
A1-A3__________Ω ∞ good
A1-Ground______Ω ∞ nothing registered no resistance
A1-Bat________Ω 200~600 Ω nothing registered no resistance
A1-M__________Ω ∞ nothing registered no resistance
A2-A1_________Ω ∞ good
A2-A3_________Ω ∞ good
A2-Ground_____Ω ∞ this registered to the far left off my chart
A2-Bat________Ω 200~600 Ω nothing registered no resistance
A2-M__________Ω ∞ nothing registered no resistance
A3-A1_________Ω ∞ good
A3-A2_________Ω ∞ good
A3-Ground_____Ω ∞ this registered to the far left off my chart
A3-Bat________Ω 200~600 Ω nothing registered no resistance
A3-M_________Ω ∞ nothing registered no resistance
Bat-m_________Ω ∞ good
Bat-G_________Ω ∞ this registered to the far left off my chart
Bat- A1,A2,AA3 _____Ω ∞ these all registered 3
M-Bat________Ω 10000Ω~∞ registered zero
M-Ground____Ω 10000Ω~∞ registered zero
M-A1,A2,A3____Ω 10000Ω~∞ these all registered 3
Ground-Bat____Ω 400-2000Ω registered zero
Ground-M_____Ω 1000-5000Ω registered zero
Ground to A1,A2,A3____Ω 200~600Ω these all registered zero
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #9 of 26 (permalink) Old 10-20-2013, 06:38 PM
I'm not too smart this week, but I think all those look good.
You need a reading on AC volts off each stator wire with all three disconnected, A1,2,3 to ground, should be 40-80 volts AC. Not DC.
I would also repeat the stator to ground continuity after it's warmed up, should be nothing from A1,2,3 to ground.
Also what DC voltage at engine off, 1100 rpm, 2500, and 3500 rpm?
post #10 of 26 (permalink) Old 10-20-2013, 09:41 PM Thread Starter
BeeSea's Avatar
all the above was with the engine off... and it was cold... according to slimvulcan riders directions.
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
