Died at stop. No electrical power of any kind. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-01-2013, 10:18 PM Thread Starter
jetmax's Avatar
Had to get towed today. Waiting for shop to identify problem.
only like 8,400 miles on my 1999 vn750. Only mod is moving the regulator to the side with custom bracket like a year ago.
More to come...
Kawasaki 1999 VN750 Mods: Relocate R/R, ETX15L battery ($44.89 Advance Auto)
Owned:
Kawasaki 1980 kz650, 1981 440ltd, 1982 750csr, 1983 550ltd, 1990 600r ninja,
1998 zx600e ninja Green, 1998 zx600e Purple,
Suzuki 1997 650 Savaga, Suzuki 1998 600 Katana
Yamaha 1982 550 Vision, Yamaha 2002 TTR125
Ducati 2001 900SS
jetmax is offline
post #2 of 6 (permalink) Old 10-01-2013, 11:15 PM
Chucklehead
dragon159's Avatar
Possibly another bad key switch?
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #3 of 6 (permalink) Old 10-02-2013, 12:52 AM
Did you check the main fuse
post #4 of 6 (permalink) Old 10-02-2013, 04:46 PM
sounds like the ignition switch needs to be rebuilt.
post #5 of 6 (permalink) Old 10-02-2013, 10:28 PM
Chasin' the blacktop
Spencer1's Avatar
Possibly the simplest thing,,,, a bad connection at the battery or a major ground wire. That or you could have accidentally bumped the kill switch, Done that myself.
North Georgia
Spencer1 is offline
post #6 of 6 (permalink) Old 10-05-2013, 08:30 PM
Concert connoisseur
wib714's Avatar
I would look for a simple groiund shorting out as well, mine did it and welded the negative wire to the battery when it worked its way loose, I also hit the kill switch by mistake once, phused it a block to work before I figured it out!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
