led? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 10-01-2013, 09:20 PM Thread Starter
led?
has anyone for a led replacement for the #67 bulb in the license plate light? ive gone thru 4 bulbs since april and had to replace it again today in order to get it inspected
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #2 of 10 (permalink) Old 10-01-2013, 11:35 PM
I remember reading something about that here once.someone will chime in
post #3 of 10 (permalink) Old 10-02-2013, 12:07 AM Thread Starter
B1156-4WAL is what most rv places are using. it fires on sides and top. i may take a chance on one to see how bright it is
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #4 of 10 (permalink) Old 10-02-2013, 12:31 AM
I know KC makes them for the back blinkers. Give him a shout out
post #5 of 10 (permalink) Old 10-02-2013, 01:14 AM
Custom Dynamics has LED Tag Boltz with plate illumination in either white or blue.
They also have
New Dual Color LED Tag Boltz: These new Dual Color Tag Boltz provide a rear facing High Power Reactor™ Amber or Red LED that can be used for a running light, brake light, or a turn signal and a white downward facing LED for tag illumination. Simple 3 wire design. Lifetime illumination warranty.
Available in a polished finish or in black.
http://www.customdynamics.com/illumi...#LED_Tag_Bolts
Does that help?
https://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would.html
post #6 of 10 (permalink) Old 10-02-2013, 02:43 AM
I.T. Analyst, Alpha Geek
FieroGT42's Avatar
Any 67 or 1156 (BA15S) base should work. Get one with radial or 90-degree facing LEDs and wide angle lenses for best lighting. I got most of my automotive LEDs from SuperBrightLEDs.com and a few from eBay.
"Fiamma" - 86˝ Pontiac Fiero GT fastback
Frame-off resto w/ Cobalt SS F23 trans swap, high lift valves, sprint headers, de-cat etc.
Track ready adjustable suspension w/ poly bushings & Herb Adams antisway bars
Too much other stuff to list. 100% built with my own two hands.
94/86 VN750s - Ears shaved, coastered, jetted, R/R moved.
FieroGT42 is offline
post #7 of 10 (permalink) Old 10-02-2013, 03:01 AM
Ndr
before you go replacing the bulb again, I would recommend checking your wiring out. you should not be going through bulbs that quickly. You may have an intermittent short causing the bubs to blow out.
That being said, I have an 1156 style LED bulb I picked up from superbrightleds.com in mine.
Ndr is offline
post #8 of 10 (permalink) Old 10-02-2013, 06:24 AM
I swapped the whole thing. I'm using a lisence plate frame with an led strip built into it.
post #9 of 10 (permalink) Old 10-02-2013, 11:56 AM
post #10 of 10 (permalink) Old 10-04-2013, 09:17 PM Thread Starter
thanks guys, i ordered a pair off amazon for 6 bucks and free 2 day shipping with prime.
what a world of difference. i have to chase some wires down to make sure theres no shorts, but im thinking its vibration
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
