stator mod progress, need opinions to make sure cutout is correct. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 09-28-2013, 03:29 PM Thread Starter
emtdon's Avatar
i used a scroll saw to cut the center out. kept some oil on the scroll saw blade to keep it from braking only used one blade i think it was a 7 pin end blade. cut at medium speed stop to let blade cool for 5 to 10 seconds. took about 2 minutes to cut. used a kids compass to mark the circle. there is just enough room to fit the cover in the scroll saw so it doesnt hit while cutting. i cut with outside facing down. cleaned the shavings out with air nozzle. then rinsed the rest out with a water house and dried really good. Glenn's mod kit test fit really good i just need to grind the ribs on the stator cover. oh yeah and need a new stator when my wife gives me my allowance lol.
Name:	using scroll saw.jpg
ID:	10834   Click image for larger version
Name:	cutout bottom view part.jpg
ID:	10842   Click image for larger version
Name:	cutout top view.jpg
ID:	10850   Click image for larger version
Name:	inside view cut.jpg
ID:	10858   Click image for larger version
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 19 (permalink) Old 09-29-2013, 09:17 AM
Glenn C.
gcextreme's Avatar
Looks good...should work great....u cut out a tad more than i did on mine..but it should be fine...
As for the stator go with a TPE one..Tim Parrot Enterprises..his are the best.
Oh and i think i might move this to the Electrical section...since all the other stator stuff is there..
Moved it...
Glenn C
Alexandria, MN
My VN750 Page
VN750 Stator Plates and Products
2001 Kawasaki Vulcan VN750
1986 Kawasaki Vulcan VN750 (being restored)
1986 Kawasaki 454LTD (being restored)
1985 Kawasaki 454LTD (being restored)
gcextreme is offline
post #3 of 19 (permalink) Old 09-29-2013, 02:14 PM Thread Starter
emtdon's Avatar
thanks, i thought the pictures may help someone who might have to do the same
Sent from Motorcycle.com App
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #4 of 19 (permalink) Old 10-19-2013, 12:41 PM Thread Starter
emtdon's Avatar
thanks
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #5 of 19 (permalink) Old 10-29-2013, 12:32 AM Thread Starter
emtdon's Avatar
since I've done the stator mod and have all new gaskets and dampers would i be able to put the engine back together and on the bike while waiting for a new stator. if so will it be hard to get the wires through the rubber grommet?
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #6 of 19 (permalink) Old 10-29-2013, 01:05 AM
If cut properly, Grommet, should not be a big problem.
That's what the mod allows you to do, a quick easy Stator removal/install.
post #7 of 19 (permalink) Old 10-29-2013, 09:24 AM
I sent my stator to TPE with the grommet, and it came back with the grommet installed.
post #8 of 19 (permalink) Old 10-29-2013, 11:03 AM
Yes, same here, with a New Grommet.
post #9 of 19 (permalink) Old 10-29-2013, 11:23 AM
As far as routing goes, you'll want to watch all the wires inside the case to be sure they can't contact the rotor. I used mini zipties to keep them together and made sure they were in the slot below the grommet.
I also re-routed the wires over the trans instead of under the side case and clutch arm.
post #10 of 19 (permalink) Old 11-05-2013, 11:30 AM
I sent a spare stator to Tim and when it came back rewound it looked solid, but for some reason he sent it back with a new grommet that is way too big for the case. This seems to be routine, but I would have preferred to have my old grommet back.
I am trying to either get the old grommet from someone or see if I can modify it to fit the existing case.
How are you dealing with this issue??
