Another R&R question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-06-2007, 09:33 PM Thread Starter
Have a 2001 750 with 21,000 miles on it. So far no electrical problems but probably should relocate the RR. Just out of curiosity, is there any average length of time they last before getting fried by the extra heat? Maybe I'm lucky or the "extra coolness" of Northern Michigan has helped. (Ha) Any thoughts?
Counselor is offline
post #2 of 8 (permalink) Old 05-06-2007, 10:34 PM
It all depends on how hot it gets where you are, how long you sit at idle in the heat, and such factors. Some people never experience R/R frying. However it never hurts to be pro active. The cost of relocating in time and money is well worth the savings gained.
Foxhound is offline
post #3 of 8 (permalink) Old 05-07-2007, 11:55 AM
fergy's Avatar
Relocating the r/r is the only thing you can do to plan for avoiding a situation where you are stuck in traffic on a hot day etc. Since those situations are usually unavoidable, relocating the r/r is the only way to be better protected.
I'm sure the cooler temps you have up there would help keep the r/r a little cooler, but the temp of the bike with stock exhaust sitting in slow moving traffic would take it's toll even in cooler weather since there isn't any airflow to sweep through the heat sinc fins on the r/r in slow traffic.
Seems like high 80's and low 90's were pretty rare when I was a kid living up there. Long long ago.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 8 (permalink) Old 05-10-2007, 11:36 PM
Benjammin'
BSkaggs513's Avatar
Quick question-
When I relocated my R/R, I coated down the terminals with Dielectric Tune Up Grease. Is that OK to use? I didn't do anything stupid did I??
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #5 of 8 (permalink) Old 05-11-2007, 12:00 AM
HAWK
Ccspinner's Avatar
That is what you want to do, good work.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #6 of 8 (permalink) Old 05-11-2007, 04:38 AM
Originally Posted by BSkaggs513 View Post
Quick question-
Only if you don't have future plans of adding some of the dielectric grease to any other connections you can get to.
So yeah, ya did it right.
post #7 of 8 (permalink) Old 05-11-2007, 10:51 AM
fergy's Avatar
I can't really vouch for the "stupid" part, since I wasn't there. You might have also changed your blinker fluid or something.
Nope! I use that stuff on all connections. You can buy a neat little can that has a nozzle on it and a trigger that injects the dielectric grease at a pretty slow rate, at autozone. Only problem is it keeps coming out of the tube for at least 10 seconds after you quit squeezing the trigger, so squeeze a little, let go and it will come out for a few seconds by its self.
You did good!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #8 of 8 (permalink) Old 05-11-2007, 02:56 PM
Tcat1000's Avatar
Changed the blinker fluid? Darn.......I've never changed mine yet! You will have to tell me where the drain plugs are! I looked & can't find them!
I suppose that I have to grease the green muffler bearings too!
I could have done that at the same time when I lubed the splines & saved some time...........Thanks a lot........
2006 VN750
Splines lubed With TSMOLY 70
R&R Relocated
Marbled (Cat's eyes no less)
Digital Volt, Amp, Temp gauge (Kisan)
Pipes Drilled
Carb Adj. at 3 3/4
Polaris AGM Battery (190 CCA)
Kaw rear rack
Kaw front engine guard
National Cycle Street Shield EX W/S
Mobile 1 MX4T 10W40 oil (Now labled 4T Racing)
Purolator PL14610 oil filter (Painted)
Iridium Spark Plugs
Pulsating Brake Light (Kisan)
My Motto: Don't get mad, just get even. Trust me, I will get even!
Tcat1000 is offline
