Won't Run HELP!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-03-2007, 05:32 PM Thread Starter
Question Won't Run HELP!!
I have a 1992 Vulcan 750 that will only run if I hold in the start button.
As soon as I let off it dies. Any help available out here would be greatly appreciated.
357bob is offline
post #2 of 7 (permalink) Old 05-03-2007, 09:32 PM
Crobins365's Avatar
Hi and welcome to the Forum! I'm guessing that you have a bad starter relay, but I'll let someone else chime in on how to troubleshoot that. If that's the problem, let me know - I have a spare sitting around.
C
Crobins365 is offline
post #3 of 7 (permalink) Old 05-03-2007, 10:41 PM
Stranger Than Fiction
cmanningjr's Avatar
Send a message via MSN to cmanningjr
You can jump out the post on the relay with some wire to see if it stays on...But that's what it sound like to me...
'92 Vn750
cmanningjr is offline
post #4 of 7 (permalink) Old 05-03-2007, 10:46 PM
93VN750's Avatar
According to the wiring diagram, the started button is related to the kill switch. You might want to check that. If not, perhaps it is in your ignition switch.
The starter relay just isolates the high current to the starter motor from the push button. If the starter spins when you press the button and stops when you release it, the relay is fine.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 7 (permalink) Old 05-03-2007, 11:21 PM
I'm just guessing here from looking at the wiring diagram in my Clymers, but it may be related to your igniter IC.
Foxhound is offline
post #6 of 7 (permalink) Old 05-03-2007, 11:57 PM
Crobins365's Avatar
Here's a gif file of the wiring diagram for the starter system. If the starter motor turns while the starter switch is pressed, then I think Jon's right, that the circuit and the starter relay are probably ok (all of those linkages are to the right side of the diagram). However, the red wire coming off the starter switch, (per Foxhound's post) does go to the ignition coil, so the troubleshooting seems like it should start there.
So, for those of us who are still learning our electrical systems, how do you test this?
C
post #7 of 7 (permalink) Old 05-04-2007, 12:20 PM
San Diego Vulcan Rider
DeForestSD's Avatar
Jon
Great info but made me think of my MSF course. Our instructors admonished us to always refer to that as the cutoff switch.
86' Vulcan, Stock & Lovin it!
Stator, R/R, splines lubed, ACCT's repl. at 25,200
Just turned 29,000 mi.
95' Vulcan, all stock, 9,700 mi.
John Spangler
DeForestSD is offline
