Fitting new RR - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-03-2007, 04:34 PM Thread Starter
Fitting new RR
Well I plumped for the RR26 in the end and I am now trying to fit it to the bike.
I have had 2 snags. The first was that when removing the old RR, one of the bolts twitsted off so i had to drill it out. This worked out ok in the end as the RR26 is thicker than the stock RR and the old bolts were not long enough to attach it. In the end I drilled out the other hole and mounted the RR with 2 nut & bolt combos.
The second problem I need some help with though. A previous owner of my bike has done a hatchet job on the old RR and the connector. It looks like one of the pins on the old RR broke off and he has cut away part of the connector so he could solder the wire direct to the RR!
links to hi-res images
http://www.auap87.dsl.pipex.com/bike/SNV30454.jpg
http://www.auap87.dsl.pipex.com/bike/SNV30455.jpg
I really don't want to be jury-rigging this but the parts diagram does not give a part number for this connector. Is it a part I can get hold of and replace?
Any advice on the best way to proceed will be gratefully accepted.
scot_vulcan is offline
post #2 of 7 (permalink) Old 05-03-2007, 11:11 PM
I don't think Kaw sells the connectors seperatly, you would have to get a whole wiring harness. I will see if I can find a supplier for the connector, electronics parts places are a good source for these. Just need to locate the correct molex style.
Foxhound is offline
post #3 of 7 (permalink) Old 05-03-2007, 11:18 PM
ebay
I think i saw a whole wiring harness going for like 10 bucks on ebay--
jetboy is offline
post #4 of 7 (permalink) Old 05-04-2007, 05:40 AM Thread Starter
Thanks but I really don't want to have to pull the whole harness.
I have found an independant auto electrical store nearby so I am going to try there. let you know how it goes later.
post #5 of 7 (permalink) Old 05-04-2007, 03:17 PM
Mushu's Avatar
Send a message via MSN to Mushu
You can fabricate your own wires with some 12 gauge cable and some 1/4" terminals and some shrink tube. Just as I did...
I think it's a better arrangement since there a bit of space between the connectors for more air flow.
The only difference is that I put the R/R on top of the radiator.
ID:	381   Click image for larger version
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #6 of 7 (permalink) Old 05-04-2007, 03:55 PM
93VN750's Avatar
I agree with Mushu, just get some 0.250 inch insulated fastons. Cut off the old crap, splice in some new leadwire (if it won't reach), and put on the fastons.
If you need the wire colors versus r/r teminals, let us know.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #7 of 7 (permalink) Old 05-04-2007, 05:10 PM
fergy's Avatar
I agree, I'd lose the connector and go with individual connectors. I think I'd also remove that electrical tape from that bundle of wires and let them be a little looser to help keep the heat down.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
