starter noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-20-2013, 08:17 PM Thread Starter
jawstec
Smile starter noise
When cranking, starter disengages for about one tooth in a ten second crank. It would be a bendix if it had one. Battery is an AGM fully charged one week old. First bike, I don't want to guess as to what to change or check first. THANKS for any help.
jawstech is offline
post #2 of 6 (permalink) Old 08-21-2013, 11:08 AM
You may need to pull the starter to see if all the teeth are in tact.
post #3 of 6 (permalink) Old 08-21-2013, 08:31 PM Thread Starter
jawstec
Teeth on idler gear and starter look perfect. However when taking off positive terminal the lockdown nut on starter was very loose. Will that cause the noise?
jawstech is offline
post #4 of 6 (permalink) Old 08-22-2013, 11:30 AM
I suppose if the starter suddenly stops turning and then starts again due to a bad connection it could sound like a "skipped tooth".
post #5 of 6 (permalink) Old 08-22-2013, 11:37 AM
Maybe the one-way starter clutch?
Agreed though, the loose lug for the cable could be a problem. Most times the locknut just needs tightened, but don't let the stud rotate and break the connection inside.
post #6 of 6 (permalink) Old 08-22-2013, 10:17 PM Thread Starter
jawstec
Taking to electrical starter shop next week after talking to dealership Saturday. THANKS for all the input, will help me sort things out. Guess that crash I had because of spilled cement did the damage to loosen connection. But I did check the cable nut to make sure it was tight. Just did not go far enough. Took two years to finally show up. Be safe out there and enjoy the ride.
jawstech is offline
