Help needed fast! Electric system cuts off no lights nothing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-20-2013, 05:19 PM Thread Starter
Young Rider
Hi guys im on my motor holiday in germany.
Twice now during driving my bike goes haywire.
The rpm tacmeter goes balistic.
Engine backfires and all electric conk out.
Sometimes it comes back start motor and conks out again.
Open fuse box check fuses and nothing wrong bought new ones just in case.
And after taking fuses out it seemed stable but 50miles out it happened again.
Had difficulty starting any way.
Its stable for now again.
But before i go again tomorrow maybe you guys have ideas.
Im in kind of a pickle.
juliascox is offline
post #2 of 12 (permalink) Old 08-20-2013, 06:24 PM
check your ignition switch...might need to take it apart and clean the "puck"
see the Verses section under electrical
post #3 of 12 (permalink) Old 08-20-2013, 06:29 PM
could it be the regulator craping out when it warms up?
post #4 of 12 (permalink) Old 08-20-2013, 06:32 PM
R/R = Relocated Redneck
Jakzen's Avatar
Wouldn't that drain the battery?
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #5 of 12 (permalink) Old 08-20-2013, 06:35 PM
yes but after the bike cools down you may be able to restart and it will run until it heats up again
post #6 of 12 (permalink) Old 08-20-2013, 07:09 PM
The regulator won't cause the bike to die, even if it's hot. It really sounds like the ignition switch
post #7 of 12 (permalink) Old 08-20-2013, 07:46 PM
ALSO check your ground connection, ground strap to frame and engine ground.
If you are on the road, you most likely won't be able to take apart the ignition switch. I suggest rotating the key several times back and forth past the start position and hopefully it will scrape the contacts clean enough to get you through your holiday.
post #8 of 12 (permalink) Old 08-21-2013, 02:20 AM Thread Starter
Young Rider
When tapping the fuse box the lights came on and off.
And then stabilized.
post #9 of 12 (permalink) Old 08-21-2013, 04:03 AM
The ignition switch does several things. I recommend putting WD-40 in it to try and clean it out. Spray some in, then stick the key in and turn it off and on several times. It could be just worn out. But then there is the fuse box thing, which would be unrelated to the ignition switch. Do you mean the junction box.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 12 (permalink) Old 08-21-2013, 02:13 PM
The fuse box...also know as the Junction Box is a sealed unit... other than the fuses, there is not much you could check.
Possibly a loose connection to the Junction box....try unplugging and re-inserting the plugs going to it. maybe just a dirty contact.
