Ign lock only lets me start if I turn it past start & back - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-12-2013, 01:20 PM Thread Starter
I.T. Analyst, Alpha Geek
FieroGT42's Avatar
So this "new" bike I got has a fiddly ignition switch. I have to go past start and then back sometimes before it will let me start. Is this common? Is there an easy fix other than swapping in a new switch? Is the switch separate from the lock? I'd hate to have to re-key it. Thanks.
Jason
FieroGT42 is offline
post #2 of 12 (permalink) Old 08-12-2013, 01:35 PM
Take it apart and clean it.....not that hard to do.
post #3 of 12 (permalink) Old 08-12-2013, 08:57 PM
Same Issue on my '89
I just bought an '89 does the exact same thing. If I ever get a day off, I will try cleaning as recommended. Let us know how you make out. Tim
TimLoon is offline
post #4 of 12 (permalink) Old 08-13-2013, 12:28 AM Thread Starter
FieroGT42's Avatar
And then it just cuts out the ignition on me in the middle of a turn. That's never happened before. I think I'll clean it tomorrow..
post #5 of 12 (permalink) Old 08-13-2013, 09:15 AM
Check the connections while you got it out. One member found a loose wire that was just intermitantly making contact. He re-soldiered the entire switch.
Be careful taking it apart there are tiny springs in there I think.....
post #6 of 12 (permalink) Old 08-13-2013, 10:04 AM
Make sure you ever so slightly stretch the little springs inside. That's what I had to do after cleaning the first time and it failing again. Now it seems good. The bike used to just turn OFF and random times and at 60mph in traffic, kinda scary.
post #7 of 12 (permalink) Old 08-13-2013, 11:08 AM
HERE is a link that shows you where to find the writeup in the Verses section as well as a link to photos.
This should explain it as well as give you tips....there are tiny springs in the switch pod...be careful not to lose them when you open it up.
post #8 of 12 (permalink) Old 08-19-2013, 08:18 PM
All is good now
Followed the instructions on this board for cleaning the ignition switch and all works well. Thanks for the help. Tm
TimLoon is offline
post #9 of 12 (permalink) Old 08-20-2013, 10:45 AM
good to hear it helped....that is why we are here.
The Verses section should be your go-to place for most issues....lots of great info in there.
post #10 of 12 (permalink) Old 08-20-2013, 08:58 PM
Next is the shaft lube
Previous owner admittedly let some maintenance go. Next onto the shaft lube and antifreeze changeover. Thanks for the guidance.
TimLoon is offline
