head lamp - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-06-2013, 10:40 PM Thread Starter
head lamp
the head lamp indicator light stop working everything els is working i tested the bulb it is good i have no clue why it stop working
i have 2 blue 12v live wires in inside the head light area not sure what they go to
any ideas
yoshi is offline
post #2 of 11 (permalink) Old 08-07-2013, 05:02 AM
gibbo's Avatar
The two blue wires were designed to go to the running lights in the two front indicators. They are live battery volts with ignition on, so need insulating. I'm not sure I understand what you mean by the head lamp indicator light, do you mean the blue main beam indicator ?
One can never have too many alternative forms of transport.
gibbo is offline
post #3 of 11 (permalink) Old 08-07-2013, 05:18 AM
the headlight indicator failure light... it should glow a stead light luminescence. if it isn't illuminating, it usually means stator failure. if it glows bright then you have a failed high beam or low beam, depending on if the high or low beams are in use.
HEAD LAMP:If either the high or low
beam burns out, the reserve lighting
system switches over to the remaining
filament automatically, and lights the
headlight failure indicator light to show
that the headlight bulb must be replaced.
post #4 of 11 (permalink) Old 08-07-2013, 09:03 AM Thread Starter
'it usually means stator failure" i just put a new one in from tim i am getting 14.3v from it so i am sure that's not it i hope
the light is off nothing but the headlight is on and high works to.
could there still be something wrong with the headlight bulb
what makes the light come on maybe i have a wire out or ....
yoshi is offline
post #5 of 11 (permalink) Old 08-07-2013, 09:24 AM
Head light works on both hi and low beam? And the whit light is off?
I noticed that you installed a MOFSET r/r, this could be the reason the light no longer illuminates. If the headlight works, I wouldn't worry about it.
The headlight works, I wouldn't worry about it
post #6 of 11 (permalink) Old 08-07-2013, 11:30 AM
the white lite is barely visible.. I can barely see mine at nite, much less during daylite
michiganteddybear is offline
post #7 of 11 (permalink) Old 08-07-2013, 11:43 AM
x2 on my bike
post #8 of 11 (permalink) Old 08-07-2013, 12:08 PM
maybe the indicator bulb burned out??
post #9 of 11 (permalink) Old 08-07-2013, 06:56 PM Thread Starter
"I noticed that you installed a MOFSET r/r, this could be the reason the light no longer illuminates. If the headlight works, I wouldn't worry about it."
i have had the MOFSET r/r for a long time and it worked but i guess it dose not mater if everything is working
just hate things not working like they should
yoshi is offline
post #10 of 11 (permalink) Old 08-07-2013, 07:14 PM
I have the MOSFET and the headlight failure indicator light glows dimly. I was just about to ask if it's supposed to do that. Now I know.
