Replacing front directional signal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-06-2007, 01:57 AM Thread Starter
MIKES86VULCAN's Avatar
Question Replacing front directional signal
Can somebody tell me about replacing my front turn signals? I did the rear for the first time and was amazed how easy that went. Now I'm looking at the front signals and see the wires going into the headlight case. Do I have to remove the headlight or just pull the wires out of it? Thanks...
Mike B.
MIKES86VULCAN is offline
post #2 of 3 (permalink) Old 04-06-2007, 07:30 AM
Crobins365's Avatar
There's a whole wiring harness behind the headlight case into which you plug the headlamp, gauges, and front turn signals. I just pulled the headlight out, and then traced the wires from the signal to the harness; pulled 'em, dielectric greased 'em, and put 'em back in. Put the headlight assembly back on (after you're sure the signal is working ) and you're good to go!
C
Crobins365 is offline
post #3 of 3 (permalink) Old 04-06-2007, 10:32 AM Thread Starter
Thumbs up
Thanks - I'll try this weekend!
Mike B.
