Kuryakyn voltmeter mounting question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-28-2007, 11:34 PM Thread Starter
Question Kuryakyn voltmeter mounting question
Hi all. I just got a Kuryakyn volt meter. For mounting, all it has is the sticky back. I don't have the MCC dashboard for our bikes. Does anyone have any ideas on where to mount the thing?. I guess it would be possible to fabricate a clamp that could be attached to the handlebars and stick the meter to that. Anybody done that? Thanks for any and all replys. Pat.
moonshiner is offline
post #2 of 9 (permalink) Old 03-29-2007, 05:58 AM
Ya could make a dual purpose bracket.
Just a flat piece of metal connecting the speedo & tach (attached at the back of each, probably need longer screws) and then put the meter in betweem them (looks like it should fit)
That'd keep the tach/speedo from bouncing around and a mount for the meter.
post #3 of 9 (permalink) Old 03-29-2007, 07:37 AM
I drilled a small hole in the top/back of the headlight bucket for the wires to go through and mounted it there. It's easily viewed between the speedo & tach, and the wiring is concealed.
baker9713 is offline
post #4 of 9 (permalink) Old 03-29-2007, 09:11 AM
Maybe velcro it.......
vulcan460 is offline
post #5 of 9 (permalink) Old 03-30-2007, 12:02 AM
Benjammin'
BSkaggs513's Avatar
Does anyone have pictures they can post of the volt meter location and mounting? I have not done this mod, but am considering it and at this point, I am clueless.
Thanks!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #6 of 9 (permalink) Old 03-30-2007, 12:06 AM
Geek
rnewell's Avatar
I think Diana has pictures in the gallery
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #7 of 9 (permalink) Old 03-30-2007, 12:26 AM
I mounted mine on the bolt cover for the bar clamps. It turned down enough that it is visible but the LED's do not distract you @ night. It is an almost perfect fit and the chrome blends right in.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #8 of 9 (permalink) Old 03-30-2007, 12:34 AM
HAWK
Ccspinner's Avatar
I took a piece of Aluminum and stuck it to the back of the housing and then stuck the meter to it
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #9 of 9 (permalink) Old 03-31-2007, 01:08 AM
Yeah but now where does your soda go!
Foxhound is offline
