tackled the engine pull today - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 03-24-2007, 07:31 PM Thread Starter
rider
global_recon's Avatar
successfully pulled the engine today with the help of a friend. it took us about five hours of work... fairly straightforward with the help of the clymer manual. wrangling the engine over to the right took some effort, but we eventually got it over. i'm sending my engine cover to toc to have them machine the easy removal mod. justice should be back on the road in no time. i'm excited.
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
post #2 of 20 (permalink) Old 03-25-2007, 12:06 AM
Uber Member
i bet your glad you are doing that huh? i know before i pulled mine i thought the money was too much. After the pull i said it was worth it and called them up
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 20 (permalink) Old 03-25-2007, 04:07 PM Thread Starter
rider
my friend is a fairly accomplished mechanic; i'm not sure i would have felt comfortable without his help... and i'm certain there's no way i would have gotten the engine physically out of the frame without him. i just couldn't justify giving all that money to a shop for labor costs; this was really my only option. glad i did it. now... the trick will be putting everything back together after i get the toc modded cover.
paul
post #4 of 20 (permalink) Old 03-26-2007, 01:50 AM
Uber Member
Once you swing the engine back into the frame, i found it was easiest to do the first mount first, then the top, and then the back. Keep them loose until the bolts are threw all 3. After that, man assembley goes quick.... make sure you also use antiseze and all the bolts on the engine, aluminum and steel dont mix otherwise. Also make sure you get all new gaskets including the bevel gear case. If you want i've already got the part numbers here. Just PM me and i'll save you the trouble of searching microfech.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #5 of 20 (permalink) Old 03-26-2007, 10:17 AM
Search Goddess
Dianna's Avatar
Two things on re-assembling..
The hardest and most frustrating was getting the front bevel gear in place and connected to the swingarm.
And after re-assembling and turning the key we heard crank, crank THUD..
the pickup coils had been reversed in the stator casing throwing the timing off 90/270.. so the round cover came off and they were switched back and she fired right up.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 20 (permalink) Old 03-26-2007, 10:38 AM
93VN750's Avatar
I found it easier to pull off the rear wheel, pull off the rear and release the pressure on the bevel gear. A little more dissassembly, but made the job MUCH easier. Plus, throw some grease on the splines while its out.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #7 of 20 (permalink) Old 03-26-2007, 08:05 PM
Uber Member
Jon
same here... once the back wheel was off, the hardest part was remembering which bolt went in which hole...This time i am labeling every part with some masking tape and a marker.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #8 of 20 (permalink) Old 03-27-2007, 09:49 PM
I use a plano tackle box with the partitions numbered. Then I just use a notebook to note what went into that numbered spot. The tackle box is sealable, and I have plenty on hand as fishing is another of my passtimes.
Foxhound is offline
post #9 of 20 (permalink) Old 04-17-2007, 05:33 PM Thread Starter
rider
going to attempt the reassembly this saturday. my new stator arrived from rick's last week, front bevel gear case and engine cover gaskets should be arriving from ron ayers on thursday and i just picked up my toc modded engine cover from the post office today. incidentally, i'd like to throw in a good word for toc manufacturing... they said they generally shoot for a same or next day turnaround after receiving the engine cover, but there was a delay with my cover due to a couple of unforeseeable factors. they threw in a set of ACCT springs and stator hex bolts at no charge. seems like a great bunch of guys at the company.
anyway, hope everything goes smoothly on saturday. really excited to get justice back on the road.
paul
post #10 of 20 (permalink) Old 04-17-2007, 05:43 PM
Stranger Than Fiction
cmanningjr's Avatar
Send a message via MSN to cmanningjr
A little tip on the engine install that worked for me...Take your front and rear wheel off, sit the engine on the floor and lift the frame of the bike over the engine, then install the bolts. It'll take a bout 20 min to do. Then I used a hoist to pick the bike back up on to the lift.
Just thought I'd share......
'92 Vn750
cmanningjr is offline
