spark plug wire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-14-2007, 08:09 PM Thread Starter
Bartman's Avatar
spark plug wire
Does anyone know where I can find the 8 mm non-resistor plug wire??? I have checked the different auto parts store in the area and they say they can't get it.
thanks
Bart
Road Captain
SCRC Valdosta,Ga #274
VROC #19066
Wet Butt Riders #253355-2
PGR
Bartman is offline
post #2 of 8 (permalink) Old 03-15-2007, 04:14 AM
They can't even order it??
There is some HERE, from Summit Racing. 25ft roll for $31.88 (+ shipping?)
Looks like blue is the only color they have the 8mm in.
It's edit time :
I found more at Summit, HERE. Black, blue, red, orange, yellow, purple, hot lime, teal and white.
But it doesn't say if it's non-resistor.
post #3 of 8 (permalink) Old 03-16-2007, 04:26 PM Thread Starter
Bartman's Avatar
Does it have to be 8mm??? I found some 7mm wire that is sold in 72" lengths.
Road Captain
VROC #19066
PGR
Bartman is offline
post #4 of 8 (permalink) Old 03-21-2007, 02:04 PM Thread Starter
Bartman's Avatar
OK.....I got my wire and plug caps today.....what about the end that goes on the ignition coil??? Do you just use the old ones???
Road Captain
VROC #19066
PGR
Bartman is offline
post #5 of 8 (permalink) Old 03-21-2007, 02:34 PM
Bart if I remember correct the wires just push into the coil
TrashLord is offline
post #6 of 8 (permalink) Old 03-21-2007, 02:38 PM Thread Starter
Bartman's Avatar
Mine have a little fitting on the end that screws onto to the coil kinda like a compression fitting
I found something in the Vulcan Verses that tells what to do!!!
thanks
Bart
Road Captain
VROC #19066
PGR
Bartman is offline
post #7 of 8 (permalink) Old 03-21-2007, 02:56 PM
93VN750's Avatar
Just re-use the compression fitting. They should last forever.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #8 of 8 (permalink) Old 03-21-2007, 10:41 PM
Sky Rider's Avatar
The Verses strike again!!!!!
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
